OpenFOAM inlet bc for pressure and velocity in case of the compr. fan or impeller
Old   October 24, 2017, 06:54
Default OpenFOAM inlet bc for pressure and velocity in case of the compr. fan or impeller
Ivan
cfdhelp is on a distinguished road
Dear friends,
I would like to ask you what boundary condition on the inlet for pressure and velocity is possible to use for the
standard OpenFOAM simulation of the compressible fan or impeller of the centrifugal compressor with the foam solver sonicFoam or similar.
For the first time, I want to use MRF and than the AMI interfaces ...
I would like to calculate the velocity as a function of the blade and the inlet part function.
Regards,
Ivan
OpenFOAM from the CFD Direct not the OpenFOAM extend.
cfdhelp is offline   Reply With Quote
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 04:19
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 07:10
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 17:24
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
