centrifugal pump tutorial
Like Tree2Likes
  • 2 Post By kandelabr
Old   October 24, 2017, 11:15
Post centrifugal pump tutorial
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
after months of wrestling with OpenFOAM I finally managed to set up a centrifugal pump case. I wrote a quick sum up of the settings and workflow and here I share the link to the case files and the text.
Hope it's of any use to anyone and if someone finds an error I'll be glad to correct it.
http://damogranlabs.com/2017/10/open...ump/#more-1116
Bashar and cfdphind like this.
kandelabr is offline   Reply With Quote
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 07:42
SIG Turbo ERCOFTAC Centrifugal Pump - OF Revision Problem? marcelgt87 OpenFOAM 18 June 26, 2012 09:59
Urgent problem! Appreciate all you help!! 3D Centrifugal Pump set up problems! RR2 FLUENT 5 April 13, 2012 09:17
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 08:39
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
