Questions overset interpolation with DyM very slow for large 3D cases |
Rep Power: 8 ![]() |
Hi guys,
At the moment I am playing around with the new overset feature of OF 1706+. Everything is fine so far, I observed just for large 3D cases and moving mesh cabalities (for example a flapping 3D airfoil) a huge decrease in speed up (overPimpleDyMFoam). This is due to the cutting hole algorithm of the overset analysis itself. There are three kinds of interpolations possible: inverseDistance trackingInverseDistance cellVolumWeight. So which one would you recommend in order to speed up the cutting hole algorithm. Mesh is changing here every time. At the moment I am using inverseDistance approach by defining a searchBox with subsequent Divisions. Thanks in advance, |
Yann
Rep Power: 12 ![]() |
I'm working with overPimpleDyMFoam on a moving object in 3D meshes and I tried the 3 algorithms on the same case.
On my case, inverseDistance and trackingInverseDistance have pretty much the same speed, while cellVolumeWeight is way much longer (about 5 times longer than inverseDistance) Those tests have been done only on one case so I'm not sure this results is valid as a general rule. Furthermore, I used the default setup for the 3 algorithms. For inverseDistance, I've seen it's possible to specify 3 parameters : layerRelax, searchBox and searchBoxDivisions. How do you use the searchBox feature and did you notice a speed up with your setup compared to the default setup? |
Display Modes | |
enabling multiprocessor for sliding mesh (DyM) cases | qjh888 | OpenFOAM Running, Solving & CFD | 5 | September 29, 2016 03:33 |
Slow Cases using HPC and PBS job scheduler | Alhasan | OpenFOAM Running, Solving & CFD | 5 | February 1, 2015 12:07 |
Questions on the overset method of unstructured grid. | Sheldon Lee | Main CFD Forum | 1 | June 5, 2014 14:54 |
Slightly embarassing questions about Rhie-Chow interpolation | mercator | Main CFD Forum | 16 | June 11, 2013 05:35 |
