October 15, 2010, 06:42 |
lift and drag coefficient
Girolamo
Rep Power: 15 |
Hello, I am new to open foam, I'm trying the tutorial 2d airfoil (simplefoam incompressible). I can not see the values of lift and drag coefficients. I have to put in the contol dict lines you suggested, but I get nothing. How can I do? thanks
functions { forces { type forces; functionObjectLibs ( "libforces.so" ); // lib to load outputControl timeStep; outputInterval 1; patches ( wall // change to your patch name ); // name of fields pName p; UName U; log true; // dump to file rhoInf 1025; CofR ( 0 0 0 ); } forcesCoeffs { type forceCoeffs; functionObjectLibs ( "libforces.so" ); // lib to load outputControl timeStep; outputInterval 1; patches ( wall // change to your patch name ); // name of fields pName p; UName U; log true; // dump to file rhoInf 1025; CofR ( 0 0 0 ); liftDir ( 0 1 0 ); dragDir ( 1 0 0 ); pitchAxis ( 0 0 0 ); magUInf 7.30; lRef 0.305; Aref 0.001525; } } |
October 18, 2010, 07:47 |
Alejandro
Rep Power: 15 |
The script looks fine, are you placing it in the controlDict? I also had some troubles running it in openfoam 1.7. In 1.6 however it works perfectly. Try it!
If you want moment coefficient you have to change the pitch axis to 0 0 1 |
October 21, 2010, 04:02 |
Vesselin Krastev
Rep Power: 20 |
Have you changed "wall" with the name of the patch (or patches) composing the airfoil?
October 21, 2010, 05:06 |
Girolamo
Rep Power: 15 |
I use open foam nn 1.7.1 but nothing happens, even if the procedure is correct. In your opinion, should I download the library "libforces?
October 22, 2010, 08:46 |
Alejandro
Rep Power: 15 |
Check if you have the libforces.so library, its shoulf be in OpenFoam1.7.1/lib/linux64GccDPOpt/libforces.so
My problem with openfoam 1.7.1 is that it says that it cannot locate p and U, so it deactivates "forces". But the same script in 1.6 works perfectly fine. Vesselin, have you tried it yourself in 1.7.0 or 1.7.1? |
October 22, 2010, 09:50 |
#6 | |
Vesselin Krastev
Rep Power: 20 |
Regards V. ps-the name of the function is not significant: it simply determines the name of the directory in which the forceCoeffs data will be stored // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 5000; deltaT 1; writeControl runTime; writeInterval 500; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; functions { totalDrag { // rhoInf - reference density // CofR - Centre of rotation // dragDir - Direction of drag coefficient // liftDir - Direction of lift coefficient // pitchAxis - Pitching moment axis // magUinf - free stream velocity magnitude // lRef - reference length // Aref - reference area type forceCoeffs; functionObjectLibs ("libforces.so"); patches ( body ); rhoName rhoInf; rhoInf 1.184; CofR (0 0 0); liftDir (0 1 0); dragDir (1 0 0); pitchAxis (0 0 1); magUInf 40; lRef 0.288; Aref 0.0561; outputControl timeStep; outputInterval 50; } |
October 25, 2010, 05:56 |
Girolamo
Rep Power: 15 |
Hello. I am studying the case of a cylinder.
these are the files that I put: { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; functions { forces { type forces; functionObjectLibs ( "libforces.so" ); // lib to load outputControl timeStep; outputInterval 1; patches ( wall // change to your patch name ); // name of fields pName p; UName U; log true; // dump to file rhoInf 1025; CofR ( 0 0 0 ); } forcesCoeffs { type forceCoeffs; functionObjectLibs ( "libforces.so" ); // lib to load outputControl timeStep; outputInterval 1; patches ( wall // change to your patch name ); // name of fields pName p; UName U; log true; // dump to file rhoInf 1025; CofR ( 0 0 0 ); liftDir ( 0 1 0 ); dragDir ( 1 0 0 ); pitchAxis ( 0 0 0 ); magUInf 7.30; lRef 0.305; Aref 0.001525; } } // Definition of terms: // rhoInf - reference density // CofR - Centre of rotation // dragDir - Direction of drag coefficient // liftDir - Direction of lift coefficient // pitchAxis - Pitching moment axis // magUinf - free stream velocity magnitude // lRef - reference length // Aref - reference area FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 101325; boundaryField { inlet { type freestreamPressure; } outlet { type freestreamPressure; } wall { type zeroGradient; } frontAndBack { type empty; } } FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (30 0 0); boundaryField { inlet { type freestream; freestreamValue uniform (30 0 0); } outlet { type freestream; freestreamValue uniform (30 0 0); } wall { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } how do I get the CD and Cp Cl?? |
October 25, 2010, 06:12 |
Girolamo
Rep Power: 15 |
i have also this error in the terminal(when i start the iteraction):
--> FOAM Warning : From function void forces::read(const dictionary& dict) in file forces/forces.C at line 277 Could not find U, p or rho in database. De-activating forces. |
October 26, 2010, 07:40 |
#9 |
Alejandro
Rep Power: 15 |
I had the same error but now its working fine. As Vesselin used, I removed the pName and uName inputs, and added the rhoName rhoInf.
It works perfect now with 1.7.1 Girolarno, I hope it works for you as well |
October 26, 2010, 08:12 |
#10 |
Girolamo
Rep Power: 15 |
Thank you so much you were very kind ...... but you may be able to plot the pressure coefficient on the wall? How do you do for plotting?
October 26, 2010, 09:49 |
#11 |
Alejandro
Rep Power: 15 |
Pressure coefficient is another story. For that you use the sampling utility. You need the following file in your system directory: sampleDict.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location system; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Set output format : choice of // xmgr // jplot // gnuplot // raw setFormat raw; // Surface output format. Choice of // null : suppress output // foamFile : separate points, faces and values file // dx : DX scalar or vector format // vtk : VTK ascii format // raw : x y z value format for use with e.g. gnuplot 'splot'. // // Note: // other formats such as obj, stl, etc can also be written (by proxy) // but without any values! surfaceFormat raw; // interpolationScheme. choice of // cell : use cell-centre value only; constant over cells (default) // cellPoint : use cell-centre and vertex values // cellPointFace : use cell-centre, vertex and face values. // 1] vertex values determined from neighbouring cell-centre values // 2] face values determined using the current face interpolation scheme // for the field (linear, gamma, etc.) interpolationScheme cellPoint; // Fields to sample. fields ( p ); // Set sampling definition: choice of // uniform evenly distributed points on line // face one point per face intersection // midPoint one point per cell, inbetween two face intersections // midPointAndFace combination of face and midPoint // // curve specified points, not nessecary on line, uses // tracking // cloud specified points, uses findCell // // axis: how to write point coordinate. Choice of // - x/y/z: x/y/z coordinate only // - xyz: three columns // (probably does not make sense for anything but raw) // - distance: distance from start of sampling line (if uses line) or // distance from first specified sampling point // // type specific: // uniform, face, midPoint, midPointAndFace : start and end coordinate // uniform: extra number of sampling points // curve, cloud: list of coordinates sets ( ); // Surface sampling definition: choice of // plane : values on plane defined by point, normal. // patch : values on patch. // // 1] patches are not triangulated by default // 2] planes are always triangulated // 3] iso-surfaces are always triangulated surfaces ( airfoil { type patch; // always triangulated patchName Airfoil; } slat { type patch; patchName Slat; } ); // ************************************************** ********************* // I got this from a tutorial, I don't remember which one, and its also explained in the user guide. After running your simulation you run the sample utility. After that you can use matlab or excel to calculate the Cp. Good luck! |
December 18, 2010, 16:22 |
#12 |
Maryam Mousazadeh
Rep Power: 15 |
Hello Alejandro,
excuse me, I have an basically question because I'm not sure. Is it enough that add mentioned lines to controlDict for calculating drag/lift coefficient in a steady state simulation? or we should copy other specific directories in our own case and use specific command during simulate? in this way can we use sampleDict to plot these coefficients? thanks |
December 19, 2010, 04:21 |
#13 |
Alejandro
Rep Power: 15 |
To calculate the drag and lift coefficient, the lines inside the controlDict are enough. After running the simulation you should have a directory in your case directory called forceCoeffs or whatever name you give to your function in your controlDict. after that, what I did was import the data in matlab and then plot it, but that depends on you. This is are the lines I added. I also include the field average in case you need it at a later stage. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 10000; stopAt endTime; endTime 20000; deltaT 1; writeControl runTime; writeInterval 2000; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; functions { forceCoeffs_combi { type forceCoeffs; functionObjectLibs ("libforces.so"); outputControl timeStep; enabled true; outputInterval 1; patches ( Slat Airfoil ); rhoName rhoInf; log true; rhoInf 1.225; CofR (0 0 0); liftDir (-0.309 0.95106 0); dragDir (0.95106 0.309 0); pitchAxis (0 0 1); magUInf 51; lRef 0.3; Aref 0.0081; } forceCoeffs_airfoil { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; enabled false; outputInterval 1; patches ( Airfoil ); log true; rhoInf 1.225; CofR (0 0 0); liftDir (-0.309 0.95106 0); dragDir (0.95106 0.309 0); pitchAxis (0 0 1); magUInf 51; lRef 0.3; Aref 0.0075; } forceCoeffs_slat { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; enabled false; outputInterval 1; patches ( Slat ); pName p; UName U; log true; rhoInf 1.225; CofR (0 0 0); liftDir (-0.309 0.95106 0); dragDir (0.95106 0.309 0); pitchAxis (0 0 1); magUInf 51; lRef 0.3; Aref 0.0001566; } fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl timeStep; outputInterval 2000; fields ( U { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; } ); } } // ************************************************** *********************** // |
December 19, 2010, 10:38 |
#14 |
Maryam Mousazadeh
Rep Power: 15 |
I thank you for your helping, but I don't know what's the usage of field average and why we should obtain it? thanks |
December 21, 2010, 04:20 |
forces.dat information
#15 |
Ovidiu Michiu
Rep Power: 16 |
i have a 2d airfoil and i used simpleFoam to run the case; i have the coefficient lift, drag and momentum. also, i have the forces calculated. my question is: when i open the forces.dat (were are the forces) file i have on the first line time, forces(pressure, viscous) momentum(pressure, viscous) and the second line i have 13 colones of numbers, corresponding to time, forces and momentum. but, why do i have 12(+1 the time) and not 9(+1 the time)? best, Ovidiu |
December 22, 2010, 08:34 |
#16 |
David Boger
Rep Power: 17 |
Based on the first line, the 12 columns are the pressure and viscous component of the force, and the pressure and viscous component of the moment. Since each of these 4 items is a vector, you have 12 columns. Plus time.
David A. Boger |
January 7, 2011, 10:49 |
#17 |
The True
Rep Power: 15 |
I have put the required function in the controlDict file, but after running there happens nothing. I was just testing an airfoil with icoFoam app. I even copied the functions from an tutorial.
functions { forces { type forceCoeffs; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 1; patches ( AirFoil // this consists of the lower and the upper camber, defined as a wall in the BC ); pName p; UName U; log true; rhoInf 1; CofR ( 0 0 0 ); liftDir (0 1 0); dragDir (1 0 0); pitchAxis ( 0 0 1 ); magUInf 25; lRef 1; Aref 1; } } |
January 7, 2011, 10:54 |
#18 |
David Boger
Rep Power: 17 |
What if you use parentheses rather than braces for the list of functions and a semicolon at the end?
functions ( forces { ... } );
David A. Boger |
January 7, 2011, 11:00 |
#19 |
The True
Rep Power: 15 |
no still doesn't do anything.
January 7, 2011, 11:06 |
#20 |
David Boger
Rep Power: 17 |
I just pasted your entry (with the modifications I already mentioned) into my controlDict and I got the desired output in forces/0/forceCoeffs.dat.
David A. Boger |
lift & drag coefficient on airfoil | n. natik | FLUENT | 8 | March 31, 2015 19:02 |
Fluent Good Lift coefficient BAD drag coefficient | Rif | Main CFD Forum | 4 | March 9, 2010 10:52 |
Drag coefficient & Lift coefficient?? | mehrdadeng | CFX | 15 | December 9, 2009 21:49 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 10:21 |
