Adjoint method. Backwards in time
Old   January 22, 2018, 12:32
Default Adjoint method. Backwards in time
Jose
jlorenzo is on a distinguished road
I'm trying to code the adjoint method for the unsteady heat equation in OpenFOAM. I am able to solve the forward problem, but I'm having some trouble with the backwards problem. Actually, I don't know how to tell OpenFoam to solve a problem backwards in time, I've tried something like runTime--, but apparently this doesn't make sense to OF. Any idea on this?
Another option I'm thinking about is to solve the adjoint problem forward in time by means of a change of variable like tau = T - t. However, in this case I have to reverse the contents in the time folders, so that data files in folder 0 go to folder T, data files in folder 1 go to folder T - 1, and so on... How could I achieve this?
Thank you.
jlorenzo is offline   Reply With Quote
Old   January 23, 2018, 12:28
Jose
I have tried the second option, reading the volScalarFields in reverse direction and saving the result. This way I can solve the adjoint problem in forward direction. However, probably there are more elegant ways of doing so, I would appreciate if someone could give some hints.
By the way, maybe this thread should go in the "Programming & Development" sub-forum, but I don't know how to move it.
writeAdjointSourceTerm.H
// Reverse source term in the adjoint equation
instantList Times = runTime.times();
scalar nTimes = Times.size() - 1;
for (label i = 1; i <= nTimes; i++)
    runTime.setTime(Times[nTimes - i + 1], nTimes - i + 1);
    volScalarField T
        IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::NO_WRITE
        mesh
    volScalarField Td
        IOobject
        "Td",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
        mesh
    runTime.setTime(Times[i], i);
    volScalarField g
        IOobject
        "g",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
        T - Td
    g.write();
Jose
Old   May 10, 2018, 18:59
Chuangxin HE
Chuangxin is on a distinguished road
Did you try using a negative time step? I find it works.
    volScalarField T
        IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
        mesh
    volScalarField Td
        IOobject
        "Td",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
        mesh
    volScalarField g
        IOobject
        "g",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
        T - Td
    g.write();
Chuangxin is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
