Multiphase Inlet Boundary Conditions
Old   January 24, 2018, 06:07
Default Multiphase Inlet Boundary Conditions
Abhinav P
abhinav.iitb005 is on a distinguished road
I want to model an annular flow at the inlet of an upward facing pipe. How can I set inlet conditions in a 2D model where 20% of the inlet face is liquid flowing on either side of the wall and 60% is gas flowing. Additionally, the gas velocity is 4 m/s and liquid velocity is 1 m/s. Please refer the image for details. I am using the interFoam solver in OpenFOAM and I believe this should be done by modifying the alpha and U for Inlet Boundary.
abhinav.iitb005 is offline   Reply With Quote
Old   January 26, 2018, 00:47
Taher Chegini
Taataa is on a distinguished road
One way would be to split the inlet to two section, and apply the appropriate boundaries accordingly. In the blockMeshDict add the required vertices, blocks, faces and boundary names.
Taataa is offline   Reply With Quote
Old   November 18, 2021, 08:16
Deepak V
deepakvil is on a distinguished road
Hello, Did you get solution for your trouble, if so, can you list the procedure
deepakvil is offline   Reply With Quote
Old   November 18, 2021, 09:14
Diego Ferrando
dferrando is on a distinguished road
Hello Deepakvil.
I am not the person who opened the thread but the second answer is right. You should create 2 separated boundary patches on the blockMeshDict or doing it with the createPatch tool (which is a bit more complicated).
So, in the case that the OP shared, you should create 3 block, left to right, liquid/gas/liquid block. When you define the boundary patches, you have to create 2 patches:
Liquid_Inlet: side faces of the picture
Gas_Inlet: Middle face
If you have a more specific problem just post it here with more information.
dferrando is offline   Reply With Quote
Old   November 22, 2021, 05:17
Default more details on my problem
Deepak V
Hello dferrando,
Thanks for the prompt reply. My problem is different from the original problem listed at the start of the thread. I am doing a air-water flow in a channel. Its a 2D, axi-symmetric with interFOAM. For 0 to R', its air and R' to R, its water. R is channel radius. I want to fix this ratio of phases at the inlet throughout my simulation. I also want to specify velocities for both of them. The idea is based on the ratio & velocity at the inlet, air bubbles will form as part of the simulation.
I tried setfields with a hemisphere at the inlet as shown in attachment. However the inlet ratio is not a constant through simulation. Also i couldn't specify individual velocities.
I am confused about how to implement this inlet BC. Can i have a single block and implement the Inlet BC or I split into two. How do i update/specify the phases(air & water) in the u file and alpha.water.orig in 0 folder?
Old   November 24, 2021, 05:19
Deepak V
Hello dferrando,
I split my blocks into two. One on top of the other.
I am successful in defining the two separate velocities at two inlet face created.
What is troubling me defining the phases at the inlet? I need help here.I want to fix one phase for each inlet face. How to i define this in alpha.water.orig file. I use interFoam.
Old   June 26, 2024, 05:48
manikandan_padmanaban
mani4be is on a distinguished road
Originally Posted by deepakvil View Post
Hello dferrando,
Hi deepakvil,
how do initialize the two different velocity in single boundary?
mani4be is offline   Reply With Quote
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
