Bish |
February 1, 2018 09:36 |
buoyantBoussineqPimpleFoam Gravity Current
3 Attachment(s)
Hi All,
I am trying to simulate a gravity current within a simple long tank.
I have a small amount of sea water (1060 kg/m^3) behind a lock on the left and the rest of the tank filled with normal water (1000 kg/m^3).
I am using buoyantBoussineqPimpleFoam with a temperature difference to model the difference in density which works out to be 20K for the sea water and 300K for the water. I am using setFields to set the temperature difference and I have attached a picture of the initial temperature conditions.
I am trying model with the lock is removed instantaneously but I fear that my boundary conditions are incorrect.
The left, bottom and right walls are all using the relevant wall functions.
I have the top as an inletoutlet (atmospheric) boundary conditions.
Below are the main variable initial conditions:
0/T.orig
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
floor1
type zeroGradient;
ceiling1
type zeroGradient;
floor2
type zeroGradient;
ceiling2
type zeroGradient;
leftWall
//type zeroGradient;
type fixedValue;
value uniform 20;
rightWall
type zeroGradient;
//type fixedValue;
//value uniform 300;
frontAndBack
type empty;
0/U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
floor1
type noSlip;
ceiling1
type pressureInletOutletVelocity;
value uniform (0 0 0);
floor2
type noSlip;
ceiling2
leftWall
type dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
floor1
type calculated;
value $internalField;
ceiling1
type calculated;
floor2
type calculated;
ceiling2
type calculated;
leftWall
type calculated;
rightWall
type calculated;
frontAndBack
type empty;
}dimensions [0 2 -2 0 0 0 0];
boundaryField
floor1
type calculated;
ceiling1
type calculated;
floor2
type calculated;
ceiling2
type calculated;
leftWall
type calculated;
rightWall
type calculated;
frontAndBack
type empty;
boundaryField
floor1
type calculated;
ceiling1
type calculated;
floor2
type calculated;
ceiling2
type calculated;
leftWall
type calculated;
rightWall
type calculated;
frontAndBack
type empty;
noSlip;
rightWall
type noSlip;
frontAndBack
type empty;
boundaryField
floor1
type calculated;
ceiling1
type calculated;
floor2
type calculated;
ceiling2
type calculated;
leftWall
type calculated;
rightWall
type calculated;
frontAndBack
type empty;
0/p
boundaryField
floor1
type calculated;
ceiling1
type calculated;
floor2
type calculated;
ceiling2
type calculated;
leftWall
type calculated;
rightWall
type calculated;
frontAndBack
type empty;
I have attached a temperature result which does not seem correct to me which is the first recorded time step. The velocity result looks correct but could be misleading.
Any help would be much appreciated.
Thanks,
Bish
