February 2, 2018, 17:46 |
icoFoam not running until end time
Sean Gorry
Rep Power: 8 |
I'm new to OpenFOAM and I'm running my first simulation (not tutorial).
So in the controlDict file I've specified a startTime = 0, endTime = 0.5, and deltaT = 0.005. The solver starts up and runs a few time steps and stops. What would be causing this to happen? This is the last output from the terminal Time = 0.025 Courant Number mean: 117.402 max: 1838.74 smoothSolver: Solving for Ux, Initial residual = 0.714445, Final residual = 9.91608e-06, No Iterations 225 smoothSolver: Solving for Uy, Initial residual = 0.712959, Final residual = 9.79209e-06, No Iterations 194 smoothSolver: Solving for Uz, Initial residual = 0.711398, Final residual = 9.59565e-06, No Iterations 192 DICPCG: Solving for p, Initial residual = 0.715978, Final residual = 0.0324444, No Iterations 56 time step continuity errors : sum local = 12.9917, global = -0.356304, cumulative = -0.546988 DICPCG: Solving for p, Initial residual = 0.094301, Final residual = 8.51343e-07, No Iterations 87 time step continuity errors : sum local = 0.00432298, global = -6.44103e-05, cumulative = -0.547053 ExecutionTime = 2.91 s ClockTime = 3 s Time = 0.03 Courant Number mean: 550.618 max: 5473.6 Last edited by Sean95; February 3, 2018 at 11:33. |
February 3, 2018, 12:08 |
Sean Gorry
Rep Power: 8 |
I have since run the simulation with parallel processing, this is what I'm getting.
Starting time loop Time = 0.005 Courant Number mean: 0.0557973 max: 22.1136 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 6.32534e-06, No Iterations 17 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0443077, No Iterations 100 time step continuity errors : sum local = 0.0355543, global = -0.00138728, cumulative = -0.00138728 DICPCG: Solving for p, Initial residual = 0.0410855, Final residual = 9.19509e-07, No Iterations 158 time step continuity errors : sum local = 3.31136e-05, global = 1.31593e-08, cumulative = -0.00138727 ExecutionTime = 0.4 s ClockTime = 0 s Time = 0.01 Courant Number mean: 18.2942 max: 86.0617 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[10352,1],6] Exit code: 145 |
February 3, 2018, 14:19 |
Uwe Pilz
Rep Power: 15 |
This Co number is way too large. You have to reduce your time step.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 3, 2018, 14:35 |
Sean Gorry
Rep Power: 8 |
That did the trick, thanks again for your assistance
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
