interDyMFoam crash
Old   March 12, 2018, 04:01
Default interDyMFoam crash
Levente Sz.
magiclevinho is on a distinguished road
Dear Users,
I m using BlueCFD on windows. The interDyMFoam crashes randomly, and I don't know what could be the problem. I m running on 4 cores, parallel. If I run on 1 core, it does the same thing. Here is the error message I get:
Courant Number mean: 0.003091657 max: 0.9789671
Interface Courant Number mean: 0.0003166461 max: 0.2135742
deltaT = 0.0002311207
Time = 0.0114485
PIMPLE: iteration 1
AMI: Creating addressing and weights between 8065 source faces and 8065 target faces
AMI: Patch source sum(weights) min/max/average = 0.2486919, 2.427861, 1.007687
AMI: Patch target sum(weights) min/max/average = 0, 2.186797, 1.007601
Execution time for mesh.update() = 0.498 s
MULES: Solving for alpha.phase1
Phase-1 volume fraction = 0.551233  Min(alpha.phase1) = -2.887992e-009  Max(alpha.phase1) = 1.000159
Phase-1 volume fraction = 0.5512331  Min(alpha.phase1) = -2.608664e-009  Max(alpha.phase1) = 1.000147
[0] Generating stack trace...
[0]
Backtrace:
        ZN10StackTraceC1Ev [0x705c1465+0x25]
                 module: D:\PROGRA~2\BLUECF~1\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
        ZN4Foam5error10printStackERNS_7OstreamE [0x1021c88+0x218]
                 module: D:\PROGRA~2\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
        ZN4Foam6sigFpe13sigFpeHandlerEi [0x1022af3+0x33]
        (No symbol) [0x405a1d]
                 module: D:\PROGRA~2\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\interDyMFoam.exe
        _C_specific_handler [0x7ffe4a866466+0x96]
                 module: C:\WINDOWS\SYSTEM32\ntdll.dll
        0_chkstk [0x7ffe4a87a07d+0x11d]
        RtlLookupFunctionEntry [0x7ffe4a7e9c58+0xab8]
        KiUserExceptionDispatcher [0x7ffe4a8790fe+0x2e]
        ZN4Foam6divideERNS_5FieldINS_6VectorIdEEEERKNS_5UListIS2_EERKNS_6TensorIdEE [0xff934b+0x84b]
        (No symbol) [0x444384]
        (No symbol) [0x440d86]
        (No symbol) [0x440ad5]
        (No symbol) [0x4a8535]
        (No symbol) [0x4013f7]
        (No symbol) [0x40152b]
        BaseThreadInitThunk [0x7ffe48672774+0x14]
                 module: C:\WINDOWS\System32\KERNEL32.DLL
        RtlUserThreadStart [0x7ffe4a840d51+0x21]
job aborted:
[ranks] message
[0] process exited without calling finalize
[1-3] terminated
---- error analysis -----
[0] on DESKTOP-93JM3T3
interDyMFoam ended prematurely and may have crashed. exit code 3
Any Suggestions?
magiclevinho is offline   Reply With Quote
Old   April 4, 2018, 08:14
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Quick answer and sorry for the late reply: The stack trace line that hints at the problem is this one:
Namely "ZN4Foam6sigFpe13sigFpeHandlerEi", where "sigFpe" can be seen in the name. This means that there was floating point exception: https://en.wikipedia.org/wiki/Signal_(IPC)#SIGFPE - usually a division by zero or some other calculation that required the result to be infinite or complex number.
I suspect that this happened due to this:
If a weight is 0, this means that there is a face that is not in contact with another AMI interface. This means that you would have to use ACMI instead, which allows for unmatched surfaces, although the unmatched ones would then be automatically matched to a wall surface... although this doesn't work all that well, at least last time I heard/saw something about it.
Old   April 4, 2018, 08:15
Levente Sz.
Thank You for your answer and time!
Trackbacks are On
interDyMFoam with VOF + 6DOF instable pbalz OpenFOAM Running, Solving & CFD 10 March 27, 2018 06:11
OpenFoam-5.x tutorial InterdyMfoam DTCHull crash Raffaele Frontera OpenFOAM 11 March 12, 2018 14:35
Crash with interDyMFoam + dynamicRefineFvMesh + 64procs RobertoRibeiro OpenFOAM Bugs 1 April 10, 2017 12:11
interDyMFoam: Crash due to cells compression FC_90 OpenFOAM Running, Solving & CFD 0 July 28, 2015 07:16
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 14:21
