The problem of bed load transport rate based on FE3.2-famesh
4 Attachment(s)
Hi all,
when i calculated the bed load transport rate (qbi=q0*τ/τi - C*|q0|dη/dxi) component in the i direction by using OpenFOAM famesh, i found the result of dη/dxi in two sides in y direction (two sides patch: symmetryPlane) is wrong by simulating the scour of pileline under current and using five layer grids. The result show the value is zero in internal face ceters in y direction, however it is very big in two sides. Please help me if someone know how to slove it. Thank you. The code::):):) //########################### bed load transport rate ###########################// hA=mesh.boundaryField()[patchID].faceCentres.z(); edgeScalarField absWLEdge = fac::interpolate(hA); areaVectorField gha = fac::edgeIntegrate(absWLEdge.mesh().Le() * absWLEdge); // or //areaVectorField gha = fac::grad(hA); areaVectorField qbA = q0A*shearN - 1.5 * mag(q0A) * gha; Best, LXJ |
Yes, you are right. The spanwise direction (i.e., x direction) is set as the velocity direction. Two sides are perpendicular to y direction, and parallel to x direction. Best, Liu |
Two questions: 1. Which Boundary conditions you set for velocity in the domain? 2. Do you start your simulation from a solution obtained by not moving the grid/potential? |
2 Attachment(s)
Thank you for you reply. First, in order to explain this answer, i show a picture for the detailed model setup (plese ignore my clumsy drawing, :)), the Boundary conditions for the velocity is set in the left side of model. Second, i attempted the simulation by not moving the mesh motion, the result of grad(hA).y() is acquired in such condition and it is showed again in the attachment. Best, Liu |
1 Attachment(s)
I need emphasize the gha.x() and gha.z() keep same variation for the five layer mesh. Just gha.y() show the error. Thank you. :):):) |
