March 21, 2012, 04:21 |
Using yPlusRAS with interFoam
Hi!
I am working on my master thesis and am fairly new to OpenFOAM. I got a problem concerning the calculation of yPLUS (or y*?) using yPlusRAS. As a part of the post processing I am trying to run yPlusRas via the terminal. However I get an error-message saying: "-> FOAM FATAL IO ERROR: keyword transportModel is undefined in dictionary / "home/linux01/OpenFOAM/linux01-.1.0/run/2D/No_moonpool_forced_flow_2D/constant/transportProperties" From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400." transportProperties looks like this: twoPhase { transportModel twoPhase; phase1 phase1; phase2 phase2; } phase1 { transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1e-06; rho rho [ 1 -3 0 0 0 0 0 ] 1000; } phase2 { transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-05; rho rho [ 1 -3 0 0 0 0 0 ] 1; } sigma sigma [ 1 0 -2 0 0 0 0 ] 0; Does anyone has a suggestion on how to solve this problem? Thanks in advance BR John |
March 30, 2012, 07:58 |
The answer to this problem was to add a transportmodel above. then yPlusRas worked.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1e-06; rho rho [ 1 -3 0 0 0 0 0 ] 1000; phase1 { transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1e-06; rho rho [ 1 -3 0 0 0 0 0 ] 1000; } phase2 { transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-05; rho rho [ 1 -3 0 0 0 0 0 ] 1; } sigma sigma [ 1 0 -2 0 0 0 0 ] 0; // ************************************************** *********************** // |
March 16, 2018, 07:05 |
Why the transportModel above uses water properties?
#3 | |
Shafik Walakaka
Rep Power: 8 |
Trying to revive this post from ages ago! Why do you set the density and viscosity as the water for the transport model above? Or does it not matter what you set it as? My question will be assuming that the phases are water and air. The concept should be the same if the phases are oil and water too? Please correct me if I'm wrong. Kind regards Shafik |
transport model, yplusras |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
Segmentation fault in interFoam run through openMPI | voingiappone | OpenFOAM | 16 | November 2, 2011 06:49 |
YPlusRas for InterFoam (Open Foam 1.7) | MrD | OpenFOAM | 0 | August 11, 2010 15:44 |
YPlusRAS and interFoam | dkingsley | OpenFOAM Bugs | 4 | April 28, 2010 09:08 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
