#1 | |
Yasemin Eldayih
Rep Power: 2 ![]() |
When I run the simulation on my own computer it is slow but working. The problem is that it seems to take 15 days. I usually using cluster and run it in parallel but this time I had the error below. Is anyone know how to solve it? Best Regards, Yasemin Quote:
Lucky Tran
Rep Power: 27 ![]() ![]() |
This is the mpi output which unfortunately doesn't tell you anything about the error. Is there are openfoam output?
When does this error appear? Does OF launch and then does some calculations or does it crash at the start? Slow is better than not working. |
#3 | |
Yasemin Eldayih
Hi Lucky Tran,
Yes, problem is not in paralel run but in the version diffrences, I guess. Running is better but I need 72 simulation in total may take 3 years to finish all. ![]() Here is the error: Quote:
I am using OpenFOAM 4.1 and cluster's is v1606. Do you have any advice? Thank you in advance, Yasemin |
#4 | |
Hosein Heidarifatasmi
Rep Power: 8 ![]() |
It seems you are using an invalid type in your function object. You may try to turn the function object off and try again. If it runs without any issue, well... you need to correct your function object. |
Yasemin Eldayih
Hi einstein_zee,
Accually, it is working in my local computer which is Openfoam-4.1 but not in cluster(v1606) that I am using for running in paralel. Thank you, Yasemin |
Thread Tools | |
Display Modes | |
Problem About Running Fluent In Linux | mitra | FLUENT | 14 | February 16, 2016 13:07 |
Problem running angledDuct tutorial of porousSimpleFoam | Anindya1 | OpenFOAM Running, Solving & CFD | 0 | January 24, 2016 11:02 |
Non- stop running for a time-dependent heat source problem | Asghari_M | OpenFOAM Programming & Development | 1 | May 11, 2015 05:13 |
Problem while running in Highperformance computing environment | Phanipavan | STAR-CD | 1 | September 11, 2013 06:42 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 06:06 |
