simpleFoam: Reynolds Stress, turbulenceProperties:R, no output
Old   April 26, 2019, 08:57
Post simpleFoam: Reynolds Stress, turbulenceProperties:R, no output
FoamingSimon is on a distinguished road
I am having troubles with extracting the Reynolds stress from a simulation. Wether I use
"simpleFoam -postProcess -func R"
or (in the controlDict)
 functions
    turbulenceFields1
        type        turbulenceFields;
        libs        ("libfieldFunctionObjects.so");
        field		R;
        writeControl        onEnd;
The result entire simulation executes well, but the extracted Reynolds stresses is the same:
No MRF models present
No finite volume options present
    functionObjects::turbulenceFields R writing field: turbulenceProperties:R
Which seems fine, except there is not output. Nothing to be found neither in the folder nor when viewing results via Paraview.
Running more postproccessing together with the Reynolds stress via the controlDict, for instance wallshear stress, works fine and produces:
    functionObjects::turbulenceFields turbulenceFields1 writing field: turbulenceProperties:R
wallShearStress wallShearStress1 write:
    writing field wallShearStress
    min/max(ground) = (-0.119511319929 -1.42561710357e-18 -2.02731918065e-05), (-0.115200085848 2.42927606607e-18 1.24279923199e-05)
But again, no Reynolds stresses. Which I need.
I am using the "Windows Binary v1812" version of OpenFOAM.
Does anyone have suggestions on what to do, to get the Reynolds stress?
Or a way of fixing my problem?
FoamingSimon is offline   Reply With Quote
Old   May 9, 2019, 03:46
Unhappy
Still no solutions in hand, but more information gathered:
When running either
postProcess -func R
or
postProcess -funcs '(turbulenceFields)'
The result is:
Executing functionObjects
--> FOAM FATAL ERROR:
Turbulence model not found in database, deactivating
    From function bool Foam::functionObjects::turbulenceFields::compressible()
    in file turbulenceFields/turbulenceFields.C at line 107.
FOAM exiting
Old   May 15, 2019, 13:55
blackpingu is on a distinguished road
Try this maybe :
 YourSolverHere -postProcess -func R
blackpingu is offline   Reply With Quote
Old   May 16, 2019, 02:41
Hello Blackpingu
Unfortunately, it does not make any difference. An excerpt of the result from running above code is:
Time = 450
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.03;
    C1              1.21;
    C2              1.92;
    sigmaEps        1.3;
    C3              0;
    sigmak          1;
Also, still no "R" in the postprocess folder
Old   May 16, 2019, 04:23
Originally Posted by FoamingSimon View Post
Hello Blackpingu
Time = 450
Reading field p
Reading field U
kEpsilonCoeffs
    Cmu             0.03;
    C1              1.21;
    C2              1.92;
    sigmaEps        1.3;
    C3              0;
    sigmak          1;
Check your time folders for a file named "turbulenceProperties:R", in folder "450" for example.
Old   May 16, 2019, 05:24
No such file nor anything similar.
If I postprocess for yplus for example, I do get a "yPlus"-file with the results.
Old   May 16, 2019, 05:56
That is strange, what case are you running?
Old   May 16, 2019, 07:03
Indeed.
It does not matter what I run, it seems.
But currently, I run a modified "turbine siting tutorial". Basically a square domain, with ABL inflow.
I have attached a 2D-ABL flow study I have made, where I cannot extract the Reynold's stresses as well.
Old   May 16, 2019, 09:40
Try to change to this in the controldict file instead of "onEnd"
turbulenceFields1
        field		R;
        writeControl        writeTime;
or
turbulenceFields1
        field		R;
        writeControl        timeStep;
Old   May 16, 2019, 10:25
Thank you for your perseverance, Blackpingu, but no - changing the writeControl to either writeTime or timeStep did not result in any Reynolds stress outputs. Neither in the postProcess folder, nor in any of the arbitrary timestep folders.
Although, the writeControl "timeStep" did result in a lot of empty folders - which makes sense, since an output is written for every time increment.
Do you have any other ideas?
Old   May 16, 2019, 10:30
Not that i can think of, but I wasn't able to run your case properly, didn't get files for U or P or anything, do you get decent results for the velocity? Which OF version are you running?
Old   May 16, 2019, 11:40
That sounds weird, as I get reasonable results, as can be seen on the attached .png-file, showing the velocity profiles through the domain.
- Did you run it via the Allrun-file?
Otherwise, you would have to copy the 0.orig and rename it 0 before running it.
Old   May 16, 2019, 15:25
Yep I did but no luck
Old   May 17, 2019, 02:20
Maybe this is due to some differences in versions of OF.
What version do you use?
And is it normally possible for you to extract the Reynolds stresses?
Old   May 17, 2019, 02:45
New error type..
Using:
postProcess -func 'components(turbulenceProperties:R)'
The result is:
Time = 0
Reading fields:
--> FOAM Warning :     functionObjects::components components(turbulenceProperties:R) failed to execute.
For each time..
Old   May 19, 2019, 14:37
I use OpenFOAM 5, and yes works everytime.
Old   October 10, 2019, 07:24
Switched OF version from the windows binary docker version to ubuntu via windows, and everything works like a charm now.
reynolds stress, v1812
Turbulent DFSEM reynolds stress calculation ssa_cfd OpenFOAM Running, Solving & CFD 0 February 1, 2019 08:23
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 16:03
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 16:38
Reynolds Stress Models Roued Main CFD Forum 20 February 8, 2000 02:58
