Is it possible to use unstructured Cartesian grid for OpenFOAM |
Rep Power: 8 ![]() |
Hi I am beginner for CFD and OpenFOAM
I am very curious the possibility of using unstructured Cartesian meshes (as shown in the picture) in OpenFOAM ![]() what software should I use to generate this type mesh??? |
Robert
Rep Power: 12 ![]() |
Hello Eric,
you can create unstructured grids using gmesh. A structure as shown in your post can be created by OpenFOAM if you snappyHexMesh and a suitable stl. file to generate the mesh. |
Sveta
Rep Power: 0 ![]() |
Hello!
I'm trying to solve the problem of thermal conductivity using, while using the snappyHexMesh. When creating a grid, 5/10 folders are created, in which the grid is stored. If I run the LaplacianFoam utility (on a uniform grid), there are also folders 5/10/15, which store the solution at different times. Accordingly, when I use the LaplacianFoam utility with snappyHexMesh, a conflict arises. How can I get rid of it? |
#4 | |
Robert
If you liked my answer to your question, please consider leaving a "Like" in return ![]() |
Display Modes | |
two point correlations on unstructured grid | LuckyTran | Visualization & Post-Processing | 0 | January 14, 2015 11:30 |
[Other] Some questions about unstructured grid. | Yanci | OpenFOAM Meshing & Mesh Conversion | 1 | November 28, 2014 11:47 |
How to generate the Cartesian grid | wyuanding | Main CFD Forum | 2 | November 28, 2011 06:35 |
2D airfoil simulation, turbulence, boundary layer, unstructured grid | louis.langouche@gmail.com | FLUENT | 0 | March 3, 2010 09:19 |
to Identify unstructured grid and structrued grid | harry | Main CFD Forum | 4 | February 17, 2006 03:10 |
