swak4Foam for openfoam 5
Like Tree1Likes
  • 1 Post By linox
Old   May 2, 2018, 04:41
Default swak4Foam for openfoam 5
Patrick
linox is on a distinguished road
I am searching for Swak4Foam for OpenFOAM 5 but could not find anything online.
Perhaps someone here could help me to this regard. Is there a swake4Foam version for openfoam 5?
Thanks,
Linox
Fahime likes this.
linox is offline   Reply With Quote
Old   May 15, 2018, 01:51
Fahime Firoozpour
Fahime is on a distinguished road
Originally Posted by linox View Post
Thanks,
Linox
Hi Patrick
have you found swak4Foam for openfoam 5 ? or should I Install openfoam4 to work with its swak4Foam?
Fahime is offline   Reply With Quote
Old   May 18, 2018, 09:11
Joachim Herb
jherb is on a distinguished road
The development branch works for OpenFOAM-5.x (but currently not with OpenFOAM-dev):
https://openfoamwiki.net/index.php/C...xisting_clones
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam openfoam-extend-swak4Foam
hg update development
or
git clone hg::http://hg.code.sf.net/p/openfoam-extend/swak4Foam openfoam-extend-swak4Foam
git checkout branches/develop
Then build it.
jherb is offline   Reply With Quote
Old   May 20, 2018, 00:30
Fahime Firoozpour
thanks a lot for your reply
I use this command:
but got this error:
Cloning into 'openfoam-extend-swak4Foam'...
fatal: Unable to find remote helper for 'hg'
do you know what should I do at this step?
Old   May 23, 2018, 07:08
Fahime Firoozpour
I use this command :
but get this error for (hg update development):
abort: no repository found in '/home/nidec' (.hg not found)!
do you know what should I do?
thanks
Old   May 28, 2018, 20:56
Zhiyong GU
THU_Gj is on a distinguished road
thanks
Maybe you should execute the update command in 'openfoam-extend-swak4Foam' directory.
THU_Gj is offline   Reply With Quote
Old   October 9, 2018, 19:57
Default Error message. Trying to install Swak4Foam on OpenFOAM 5.0
Chris Harding
HappyS5 is on a distinguished road
Please help. I supply the log below.
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/happys5/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
Current OpenFOAM version is 5.0.
This is a clean install
/home/happys5/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Using python2.7 at /usr/bin/python2.7-config for python2
Using our own Lua at /home/happys5/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 0.4.2
Could not get version of the sources
Bison: /home/happys5/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison is version 3.0.4
Flex is version 2.6.4 (Minor version: 4)
No swak4FoamParsers/foamVersion4swak.H. Generated
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
I/opt/openfoam5/src/finiteVolume/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/sampling/lnInclude -I/opt/openfoam5/src/fileFormats/lnInclude -I/opt/openfoam5/src/triSurface/lnInclude -I/opt/openfoam5/src/dynamicMesh/lnInclude -I/opt/openfoam5/src/lagrangian/basic/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/opt/openfoam5/src/OpenFOAM/lnInclude -I/opt/openfoam5/src/OSspecific/POSIX/lnInclude   -fPIC -c CommonValueExpressionDriver.C -o Make/linux64GccDPInt32Opt/CommonValueExpressionDriver.o
/opt/openfoam5/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/CommonValueExpressionDriver.o' failed
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
What do I need to do to get up and running?
If I need to patch, can you teach me how to patch? I am new to Linux.
HappyS5 is offline   Reply With Quote
Old   October 11, 2018, 19:10
Chris Harding
thanks
Go to the "openfoam-extend-swak4Foam" folder and try: hg update develop instead of hg update development.
Thread Tools
Trackbacks are On
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 10:31
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 82 July 18, 2015 17:16
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
