Viscoelastic simulation - checkerboard problem and low pressure |
May 11, 2018, 16:40 |
Rep Power: 9 |
Hi all,
I'm doing some viscoelastic simulations using viscoelasticFluidFoam in combination with the Leonov model and I'm experiencing a strong checkerboard pattern in the velocity field. Also, the inlet pressure is far too low with a fixed inlet velocity. My experience with viscoelastic fluid simulations is rather limited, I mainly had to focus on getting it to run at all. I can't post the whole model due to a NDA, but I used the standard settings found in the Leonov test case in OpenFOAM Extend 4.0. I can't post the viscoelasticProperties dict since the settings aren't publicly available, but the relaxation time constant lambda and shear modulus G are known with which I calculated eta_p. There are only sigmafirst and taufirst listed below, but the other ones are identical. I know that it is a niche subject, but maybe someone has experienced similar issues. I was able to find out that the checkerboard problem is linked to the pressure-velocity decoupling and the staggered/collocated grid approach. OF apparently uses a mix of both grid types. Would a different interpolation routine of higher order be able to get rid of this behaviour? Code:
FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "liblduSolvers.so" //"libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); OptimisationSwitches { commsType nonBlocking; } application viscoelasticFluidFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 1e-5; writeControl adjustableRunTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; graphFormat raw; runTimeModifiable yes; adjustTimeStep on; maxCo 0.8; maxDeltaT 0.0005; // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phi,sigma) Gauss upwind; div(phi,sigmafirst) Gauss upwind; div(phi,sigmasecond) Gauss upwind; div(phi,sigmathird) Gauss upwind; div(phi,sigmafourth) Gauss upwind; div(tau) Gauss linear; div(taufirst) Gauss linear; div(tausecond) Gauss linear; div(tauthird) Gauss linear; div(taufourth) Gauss linear; } laplacianSchemes { default none; laplacian(etaPEff,U) Gauss linear corrected; laplacian(etaPEff+etaS,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default corrected; } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner Cholesky; tolerance 1e-07; relTol 0; minIter 0; maxIter 800; } U { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; } sigma { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; }; sigmafirst { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; }; sigmasecond { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; }; sigmathird { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; }; sigmafourth { solver BiCGStab; preconditioner ILU0; tolerance 1e-6; relTol 0; minIter 0; maxIter 1000; }; } PISO { nCorrectors 2; nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 0; } relaxationFactors { p 0.2; U 0.2; tau 0.2; } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } fixedWalls { type zeroGradient; } outlet { type fixedValue; value uniform 0; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.009279 0 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volSymmTensorField; object sigmafirst; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform (50 0 0 50 0 50); boundaryField { inlet { //type fixedValue; //value uniform (0 0 0 0 0 0); type zeroGradient; } fixedWalls { type zeroGradient; } outlet { type zeroGradient; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volSymmTensorField; object tau; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform (0 0 0 0 0 0); boundaryField { inlet { //type fixedValue; //value uniform (0 0 0 0 0 0); type zeroGradient; } fixedWalls { type zeroGradient; } outlet { type zeroGradient; } } // ************************************************************************* // |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | CFX | 9 | June 4, 2015 16:48 |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | FLUENT | 0 | June 3, 2015 20:17 |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | FLUENT | 0 | June 3, 2015 20:16 |
Low pressure de Laval simulation convergence problem | heksel8i | FLUENT | 3 | July 22, 2013 10:28 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
