How to add my own property to the fluids in openfoam?
I am working on a project where i need to show simulation of dirty water coming from a source and dumping it into a river(openFOAM is to be used). So here i want to show how the properties of river water changes when dirty water is dumped into the river like- salinity ,dissolved oxygen, turbidity etc. I need to make something like this: https://www.youtube.com/watch?v=0K2QBjFS5VM but as in this video we can see how temperature and velocity changes , so can we add our own properties? Thanks in advance |
You'll probably have to do something similar to this:
https://openfoamwiki.net/index.php/H...ure_to_icoFoam |
First you'd have to find a suitable solver that includes most of the governing equations of the desired parameters. The remaining terms can be added to the solver, as mentioned by krikre, based on their valid mathematical definition and equation. If you're new to OF keep in mind that changing a solver is not a trivial task.
However, if the quantity you want to solve is based on other phenomena such as gravity, drag forces etc. you have to change the equation and add the source terms. In addition, if the quantity influences the flow (momentum) you have to couple them. Good luck. |
