v1806 soloshingTank3D6DoF error when running in parallel
Dear OpenFoamers,
I am wondering if you can give some guideance on how to fix this error: Recently compiled v1806 on Ubuntu 1804. The tutorial case, sloshingTank3D6DoF ran successfully when ran in series. When I tried "mpirun -np 6 interFoam -parallel", I got the following error: [0] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [1] [1] [1] file: IOstream.PIMPLE [1] [1] From function bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [1] in file cfdTools/general/findRefCell/findRefCell.C at line 92. [1] FOAM parallel run exiting ----- Did I issue the commend wrong? Thanks! Pei-Ying |
