No MRF models present.No finite volume options present |
August 4, 2018, 20:49 |
Raj Kiran
Rep Power: 7 |
Hello ,
I am a beginner in OpenFoam and trying to simulate aerofoil case with different solvers. I tried with the pisoFoam by changing few conditions but am facing this issue. Help me out with the situation. thank you , regards, raj |
August 7, 2018, 11:33 |
mauricio
Rep Power: 17 |
Does a regular tutorial using the pisoFoam application work? if it does, then i suggest you to fit your case to this particular pisoFoam tutorial. Then, you pick the other solver you want to use and adapt the boundary conditions, the /constant and /system folder and its files to what you wish. That would be my first approach
Best Regards /calim "Elune will grant us the strength" |
interFoam: No finite volume options present | mehdinekooee | OpenFOAM Running, Solving & CFD | 4 | July 15, 2014 11:05 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
The aspect ratio of the volume elements in Finite Volume Method | CharlieTan84 | Main CFD Forum | 3 | August 28, 2012 02:34 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
