Cyclic boundary error in reactingParcelFilmFoam
Hello.
I am trying to simulate flow in a bifurcating channel (one inlet named INLET and 2 outlets coupled as OUTLETS) with surface film on it. The solver I'm trying to use is reactingParcelFilmFoam. But I face the following error: AMI: Creating addressing and weights between 56 source faces and 101 target faces --> FOAM Warning : From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>] in file lnInclude/AMIMethod.C at line 57 Source and target patch bounding boxes are not similar source box span : (0.05119999904 0.05118754041 1.52368e-006) target box span : (0.1997277537 0.04618446137 0.0378344416) source box : (-0.02559999952 -0.02559712399 -0.1000011034) (0.02559999952 0.02559041642 -0.09999957972) target box : (-0.09986398835 -0.02308501394 0.1047726057) (0.0998637653 0.02309944743 0.1426070473) inflated target box : (-0.1102869948 -0.03350802035 0.09434959929) (0.1102867717 0.03352245384 0.1530300537) --> FOAM FATAL ERROR: Unable to find initial target face From function bool Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(Foam::labelListList&, Foam::scalarListList&, Foam::labelListList&, Foam::scalarListList&, Foam::label&, Foam::label&) [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >; Foam::label = int] in file lnInclude/AMIMethod.C at line 127. FOAM aborting For creating the surface film I use extrudeToRegionMesh. Is there any way to run this case without having the new surface films boundaries as cyclic? The polymesh generated by default after extrudeToRegionMesh is as follows: ( INLET { type patch; nFaces 56; startFace 23224; } OUTLETS { type patch; nFaces 101; startFace 23280; } wallFilmFaces_top { type patch; nFaces 15535; startFace 23381; } region0_to_wallFilmRegion_wallFilmFaces { type mappedWall; inGroups 1(wall); nFaces 15535; startFace 38916; sampleMode nearestPatchFace; sampleRegion region0; samplePatch region0_to_wallFilmRegion_wallFilmFaces; offsetMode nonuniform; offsets nonuniform List<vector> Thank you |
