heating pipe
Hi guys! Im solving incompressible flow in a 2D axisymmetrical pipe with heat transfer in steady state, but i have problem with my work.
First I modify simpleFoam solver and I name it simpleThermFoam, this is how I modified the solver : createFields.H : Info<< "Reading field p\n" << endl; volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("U",dimensionSet(0,1,-1,0,0,0,0),vector::zero) ); #include "createPhi.H" label pRefCell = 0; scalar pRefValue = 0.0; setRefCell(p, mesh.solutionDict().subDict("SIMPLE"), pRefCell, pRefValue); //mesh.setFluxRequired(p.name()); singlePhaseTransportModel laminarTransport(U, phi); autoPtr<incompressible::turbulenceModel> turbulence ( incompressible::turbulenceModel::New(U, phi, laminarTransport) ); Info<< "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ); Info<< "Reading density rho\n" << endl; dimensionedScalar rho ( transportProperties.lookup("rho") ); Info<< "Reading heat capacity Cp\n" << endl; dimensionedScalar Cp ( transportProperties.lookup("Cp") ); Info<< "Reading konductivity k\n" << endl; dimensionedScalar k ( transportProperties.lookup("k") ); simpleThermFoam.C : #include "fvCFD.H" #include "singlePhaseTransportModel.H" #include "turbulentTransportModel.H" #include "simpleControl.H" #include "fvIOoptionList.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" simpleControl simple(mesh); #include "createFields.H" #include "createMRF.H" #include "createFvOptions.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; // --- Pressure-velocity SIMPLE corrector { #include "UEqn.H" #include "pEqn.H" } laminarTransport.correct(); turbulence->correct(); // --- Temperature field solve ( fvm::ddt(rho * Cp, T) + rho * Cp * fvm::div(phi, T) - fvm::laplacian(k, T) ); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } and then I modify totalTemperature boundary condition and I name it convectiveHeatFlux, this is how I modify the boundary condition : convectiveHeatFluxFvPatchScalarField.H : #ifndef convectiveHeatFluxFvPatchScalarField_H #define convectiveHeatFluxFvPatchScalarField_H //#include "fixedValueFvPatchFields.H" #include "fvPatchFields.H" #include "fixedGradientFvPatchFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { /*---------------------------------------------------------------------------*\ Class convectiveHeatFluxFvPatchScalarField Declaration \*---------------------------------------------------------------------------*/ class convectiveHeatFluxFvPatchScalarField : public fixedGradientFvPatchScalarField { // Private data //- Name of the temperature field word TName_; public: //- Runtime type information TypeName("convectiveHeatFlux"); // Constructors //- Construct from patch and internal field convectiveHeatFluxFvPatchScalarField ( const fvPatch&, const DimensionedField<scalar, volMesh>& ); //- Construct from patch, internal field and dictionary convectiveHeatFluxFvPatchScalarField ( const fvPatch&, const DimensionedField<scalar, volMesh>&, const dictionary& ); //- Construct by mapping given convectiveHeatFluxFvPatchScalarField // onto a new patch convectiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField&, const fvPatch&, const DimensionedField<scalar, volMesh>&, const fvPatchFieldMapper& ); //- Construct as copy convectiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField& ); //- Construct and return a clone virtual tmp<fvPatchScalarField> clone() const { return tmp<fvPatchScalarField> ( new convectiveHeatFluxFvPatchScalarField(*this) ); } //- Construct as copy setting internal field reference convectiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField&, const DimensionedField<scalar, volMesh>& ); //- Construct and return a clone setting internal field reference virtual tmp<fvPatchScalarField> clone ( const DimensionedField<scalar, volMesh>& iF ) const { return tmp<fvPatchScalarField> ( new convectiveHeatFluxFvPatchScalarField(*this, iF) ); } // Evaluation functions //- Update the coefficients associated with the patch field virtual void updateCoeffs(); //- Write virtual void write(Ostream&) const; }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************** *********************** // convectiveHeatFluxFvPatchScalarField.C : #include "convectiveHeatFluxFvPatchScalarField.H" #include "addToRunTimeSelectionTable.H" #include "fvPatchFieldMapper.H" #include "volFields.H" #include "surfaceFields.H" // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::convectiveHeatFluxFvPatchScalarField::convec tiveHeatFluxFvPatchScalarField ( const fvPatch& p, const DimensionedField<scalar, volMesh>& iF ) : fixedGradientFvPatchScalarField(p, iF), TName_("T") {} Foam::convectiveHeatFluxFvPatchScalarField::convec tiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField& ptf, const fvPatch& p, const DimensionedField<scalar, volMesh>& iF, const fvPatchFieldMapper& mapper ) : fixedGradientFvPatchScalarField(ptf, p, iF, mapper), TName_(ptf.TName_) {} Foam::convectiveHeatFluxFvPatchScalarField::convec tiveHeatFluxFvPatchScalarField ( const fvPatch& p, const DimensionedField<scalar, volMesh>& iF, const dictionary& dict ) : fixedGradientFvPatchScalarField(p, iF), TName_(dict.lookupOrDefault<word>("T", "T")) { fvPatchField<scalar>::operator=(patchInternalField ()); gradient() = 0.0; } Foam::convectiveHeatFluxFvPatchScalarField::convec tiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField& tppsf ) : fixedGradientFvPatchScalarField(tppsf), TName_(tppsf.TName_) {} Foam::convectiveHeatFluxFvPatchScalarField::convec tiveHeatFluxFvPatchScalarField ( const convectiveHeatFluxFvPatchScalarField& tppsf, const DimensionedField<scalar, volMesh>& iF ) : fixedGradientFvPatchScalarField(tppsf, iF), TName_(tppsf.TName_) {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // void Foam::convectiveHeatFluxFvPatchScalarField::update Coeffs() { if (updated()) { return; } const fvPatchField<scalar>& T = patch().lookupPatchField<volScalarField, scalar>(TName_); const dictionary& transportPropertiesIsolant = db().lookupObject<IOdictionary> ("transportProperties"); dimensionedScalar Tsur (transportPropertiesIsolant.lookup("Tsur")); dimensionedScalar h (transportPropertiesIsolant.lookup("h")); dimensionedScalar k (transportPropertiesIsolant.lookup("k")); gradient() = h.value() / k.value() * (Tsur.value() - T); fixedGradientFvPatchScalarField::updateCoeffs(); } void Foam::convectiveHeatFluxFvPatchScalarField::write( Ostream& os) const { fvPatchScalarField::write(os); writeEntryIfDifferent<word>(os, "T", "T", TName_); writeEntry("value", os); } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { makePatchTypeField ( fvPatchScalarField, convectiveHeatFluxFvPatchScalarField ); } and this is how I make my case : 0/p : FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { axis { type symmetry; } inlet { type zeroGradient; } pipe { type zeroGradient; } outlet { type fixedValue; value uniform 0; } front { type wedge; } back { type wedge; } } 0/T : FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 20; boundaryField { inlet { type fixedValue; value uniform 20; } outlet { type zeroGradient; } pipe { type convectiveHeatFlux; } axis { type symmetry; } front { type wedge; } back { type wedge; } } 0/U : FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { axis { type symmetry; } inlet { type fixedValue; value uniform (0.1 0 0); } pipe { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } front { type wedge; } back { type wedge; } } blockMeshDict : convertToMeters 0.01; vertices ( (0 0 0) (0 0.9990482216 -0.0436193874) (0 0.9990482216 0.0436193874) (10 0 0) (10 0.9990482216 -0.0436193874) (10 0.9990482216 0.0436193874) ); blocks ( hex (0 1 2 0 3 4 5 3) (30 1 300) simpleGrading (0.1 1 1) ); edges ( ); boundary ( axis { type symmetry; faces ( (0 3 3 0) ); } inlet { type patch; faces ( (0 0 2 1) ); } pipe { type wall; faces ( (2 5 4 1) ); } outlet { type patch; faces ( (3 4 5 3) ); } front { type wedge; faces ( (0 3 5 2) ); } back { type wedge; faces ( (0 1 4 3) ); } ); mergePatchPairs ( ); fvSchemes : FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss limitedLinear 1; div(phi,epsilon) bounded Gauss limitedLinear 1; div(phi,omega) bounded Gauss limitedLinear 1; div(phi,v2) bounded Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(nonlinearStress) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } fvSolution : FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } T { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 0; //pRefCell 0; //pRefValue 0; consistent yes; residualControl { p 1e-6; U 1e-2; T 1e-6; } } relaxationFactors { fields { p 0.3; T 0.7; } equations { U 0.7; // 0.9 is more stable but 0.95 more convergent } } controlDict : FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleThermFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1000; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; libs ( "lconvectiveHeatFlux.so" ); but when I run the program the terminal said this : /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-d8a290b55d28 Exec : simpleThermFoam Date : Aug 20 2018 Time : 15:19:12 Host : "DESKTOP-GDC6B34" PID : 1268 Case : /home/naufal/OpenFOAM/naufal-3.0.1/run/Ex8 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 0.01 field T tolerance 1e-06 Reading field p Reading field U --> FOAM Warning : From function GeometricField<Type, PatchField, GeoMesh>::readIfPresent() in file /home/naufal/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/GeometricField.C at line 106 read option IOobject::MUST_READ or MUST_READ_IF_MODIFIED suggests that a read constructor for field U would be more appropriate. Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field T Reading transportProperties Reading density rho Reading heat capacity Cp Reading konductivity k No MRF models present No finite volume options present Starting time loop Time = 1 --> FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch inlet of field U in file "/home/naufal/OpenFOAM/naufal-3.0.1/run/Ex8/0/U" You are probably trying to solve for a field with a default boundary condition. From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 199. FOAM exiting Does anyone know how to solve this error? thanks a lot. |
