picture "cracked" on paraFoam
1 Attachment(s)
Hi guys, I am working on heat transfer in porous media, and I have a problem with my paraview when I run paraFoam on my terminal.
On my case, the flow is driven by pressure gradient, when I put low pressure on my case, it seems fine, but when I put higher pressure, the picture in paraview seems broken like this : https://www.cfd-online.com/Forums/at...1&d=1535544130 I think my problem is because the temperature is very high and it makes my flow is turbulent, how can I insert the turbulent characteristic on my solver? I make my own solver named darcyTemperatureFoam, here is my createFields.H : Info<< "Reading field p\n" << endl; volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("U",dimensionSet(0,1,-1,0,0,0,0),vector::zero) ); surfaceScalarField phi ("phi", linearInterpolate(U) & mesh.Sf()); Info<< "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ); Info<< "Reading diffusivity DT\n" << endl; dimensionedScalar DT ( transportProperties.lookup("DT") ); Info<< "Reading porosity eps\n" << endl; dimensionedScalar eps ( transportProperties.lookup("eps") ); Info<< "Reading solidHeatCapacities rhoCps\n" << endl; dimensionedScalar rhoCps ( transportProperties.lookup("rhoCps") ); Info<< "Reading fluidHeatCapacities rhoCpf\n" << endl; dimensionedScalar rhoCpf ( transportProperties.lookup("rhoCpf") ); Info<< "Reading permeability k\n" << endl; dimensionedScalar k ( transportProperties.lookup("k") ); Info<< "Reading fluid viscosity mu\n" << endl; dimensionedScalar mu ( transportProperties.lookup("mu") ); and here is my darcyTemperatureFoam.C #include "fvCFD.H" #include "simpleControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" simpleControl simple(mesh); #include "createFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nCalculating pressure distribution\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; while (simple.correctNonOrthogonal()) { solve ( fvm::laplacian(k/mu, p) ); } U = -k/mu*fvc::grad(p); phi = linearInterpolate(U) & mesh.Sf(); solve ( (eps*rhoCpf+(1.-eps)*rhoCps)*fvm::ddt(T) + rhoCpf*fvm::div(phi, T) == fvm::laplacian(DT, T) ); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } |
