Creating meshes for FSI simulation
Old   September 5, 2018, 12:13
Default Creating meshes for FSI simulation
Sangeet
sangeet is on a distinguished road
I am currently trying to simulate blood flow inside an artery. I am using fsiFoam to solve the FSI problem. But I am having problems with meshing the solid artery wall and the fluid domain. Initially I tried to mesh them separately in snappyHexMesh but while trying to run the solver, I get an error of "Master point addressing not correct" . I suspect this is because of the gaps between the meshes.
I then tried multi-region meshing in snappyHexMesh but for some reason, the cellzone for the solid has 0 or very less (when the make the background mesh finer) number of cells assigned to it and when I run splitMeshRegions, it gives the fluid cellzone as the background mesh minus the fluid domain and an empty solid cellzone.
Could anyone give me pointers on how are meshes for FSI usually built? Maybe in snappyHexMesh or some other software like ICEM CFD? Or if anyone could guess why the cellzones arenot being correctly built by snappyHexMesh, do I need to just refine the background mesh a lot?
I have also attached an image of my geometry.
my snappyHexMeshDict
geometry
    FLUID.stl
        type triSurfaceMesh;
    SOLID.stl
castellatedMeshControls
    maxLocalCells 2000000;
    maxGlobalCells 4000000;
    minRefinementCells 0;
    nCellsBetweenLevels 3;
    features
            file "FLUID.eMesh";
            level 0;
            file "SOLID.eMesh";
            level 0;
    refinementSurfaces
        FLUID.stl
            level (1 1);
            faceZone fluid;
            cellZone fluid;
            cellZoneInside inside;
        SOLID.stl
            level (1 1);
            faceZone solid;
            cellZone solid;
    resolveFeatureAngle 150;
    refinementRegions
    locationInMesh (0 0 50);
    allowFreeStandingZoneFaces false;
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 100;
    nRelaxIter 5;
    nFeatureSnapIter 4;
    implicitFeatureSnap false;
     explicitFeatureSnap true;
     multiRegionFeatureSnap true;
sangeet is offline   Reply With Quote
Old   October 3, 2019, 13:30
alberto
dewey is on a distinguished road
Did you find a solution?
I am trying to simulate FSI aneurysm but Im stuck with the solid mesh too.
dewey is offline   Reply With Quote
fsi, fsifoam, snappyhexmesh
Train - Simulation Moving Meshes pippi OpenFOAM 3 February 14, 2012 09:02
Creating thin-surfaces for CFX Meshes Orb CFX 0 February 13, 2012 01:34
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Creating Table of Variable versus Time in Transient simulation in CFX 11 cjhaw CFX 2 January 15, 2011 11:52
[blockMesh] Tutorial for Creating Simple 3D Meshes jonlemur OpenFOAM Meshing & Mesh Conversion 4 August 8, 2007 13:20
