Simulation not working after OpenFoam upgrade from 3 to 5 |
September 25, 2018, 09:07 |
Dear all
I have a multiphaseEulerFoam case which was working with OpenFOAM-3.0.x. It has a spiral structure in which water is injected from the inlet and flows through the spiral. I have installed OpenFOAM-5.x on a different system and ran the same program. It shows working but when I checked carefully, I coScreenshot from 2018-09-25 18-31-55.jpguld see that the water has inlet velocity but even after a much longer time it does not flows into the spiral. However, the same flowing in OpenFOAM-3.0.x setup. What has majorly changed? A snapshot and case directory is attached for your reference. The case file is at https://drive.google.com/file/d/1iPl...ew?usp=sharing |
September 27, 2018, 17:30 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
September 28, 2018, 04:58 |
[Solved}
Got the solution. Probably new version does not support or support in other way the flowRateInletVelocity for inlet. Anyway, I calculated and gave values as fixedValue boundary condition.
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Question on transient simulation in OpenFOAM and FLUENT | nicklj | OpenFOAM Running, Solving & CFD | 4 | May 8, 2014 22:30 |
