Huge increase of RAM makes parallel mpirun fails
Old   November 8, 2017, 09:34
Question Huge increase of RAM makes parallel mpirun fails
Charlie Barraud
choch is on a distinguished road
I am trying to launch a 2D simulation in my University cluster which runs on SLURM workload manager. My case is quite simple, the mesh being regular and homogeneous.
I tested it on my local machine and there is no problem but when running in the cluster, the RAM hugely increases leading to the fail of the work "slurmstepd: error: Exceeded job memory limit at some point."
The available memory is 45 GB. In my local machine only 2 GB are used anyway. Now the weird thing is that I was so desperate so I tried to run a 2,500,000 cells case which was successful. This randomness is a bit disorientating. Could it come from the MPI settings of the cluster ?
Any one had the same issue ?
I thank you all for your time and hope you can provide me with some help,
Charlie
choch is offline   Reply With Quote
Old   November 11, 2018, 16:38
M. Montero
be_inspired is on a distinguished road
Here the same problem. Did you find how to solve it?
be_inspired is offline   Reply With Quote
Old   November 12, 2018, 10:42
Edward
EJohn is on a distinguished road
If your case file runs perfectly on your local machine, then there must be an issue with either your SLURM script file or the MPI settings on the cluster.
I would first double check my script files to make sure my code is correct and then try asking your University cluster administrator for help.
EJohn is offline   Reply With Quote
cluster computing, mpi error, parallel calculation, ram issues
[snappyHexMesh] Error while running SnappyHex in parallel mg.mithun OpenFOAM Meshing & Mesh Conversion 1 February 10, 2016 13:13
MPIRUN fails lfbarcelo OpenFOAM 3 March 29, 2010 07:41
1.6.x -> snappyHexMesh in parallel fails ... podallaire OpenFOAM Bugs 11 August 4, 2009 13:57
Does it metter to increase RAM for solver speed?? raima Main CFD Forum 1 February 28, 2008 10:47
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 12:44
