PengRobinson in foam ext 3.2
Old   September 30, 2018, 11:05
Lightbulb PengRobinson in foam ext 3.2
Enrico De Filippi
EnricoDeFilippi is on a distinguished road
Hi, I'm simulating an axial turbine with real gas. I'm using foam ext 3.2 because I need to use the mixing plane approach but it seems to have problem with interpolation with 4.0.
So, I'd like to know if someone can help me to set exactly the constant/thermophysicalProperties file and maybe tell what I've to do to add PengRobinson library to foam ext 3.2.
At the moment I've set:
thermoType
type hePsiThermo;
mixture pureMixture;
transport polynomial;
thermo hPolynomial;
equationOfState PengRobinsonGas;
specie specie;
energy sensibleEnthalpy;
mixture
specie
nMoles 1;
molWeight 134.05;
equationOfState
Tc 427.16;
Vc 0.0025928;
Pc 36.51e5;
omega 0.3776;
thermodynamics
Hf 0;
Sf 0;
CpCoeffs<7> (6.06394716678908 0.0267462245188099 -1.40821177584876e-8 0 0 0 0);
transport
mu 2.1348e-05:
Pr 0.0048;
Moreover, I've addded the PengRobertson library to /foam/foam-extend-3.2/src/thermophysicalModels/specie/equationOfState taken from https://github.com/OpenFOAM/OpenFOAM...engRobinsonGas but the error i get is: --> FOAM FATAL IO ERROR:
Attempt to return dictionary entry as a primitive
file: /home/enrico/S1R1_3_new/constant/thermophysicalProperties::thermoType from line 23 to line 29.
From function ITstream& primitiveEntry::stream() const
in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 82.
FOAM aborting
Any help will be appreciated. Thanks in advance.
EnricoDeFilippi is offline   Reply With Quote
Trackbacks are On
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 15:11
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 15:00
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 09:19
