Energy equation in RhoPimple solvers
Does anyone know where the Energy equation is solved in rhoPimple algorithm? From what I understood, the algorithm "chronological order" is the following: 1- Pressure is guessed 2- Momentum equations provide Velocity 3- Velocity is inserted into Mass equation to provide Pressure 4- Pressure is used to correct Velocity Then, the cycle restarts. In some books, I read that Energy equation (to provide Density) is solved between steps 2-3, while in other books I found that it is the last step (after step 4). Most likely, something is missing in my reasoning. Could someone help me, please? Thank you in advance, Tommy M. |
