October 22, 2018, 07:34 |
Energy equation in RhoPimple solvers
Tommaso M.
Rep Power: 7 |
Does anyone know where the Energy equation is solved in rhoPimple algorithm? From what I understood, the algorithm "chronological order" is the following: 1- Pressure is guessed 2- Momentum equations provide Velocity 3- Velocity is inserted into Mass equation to provide Pressure 4- Pressure is used to correct Velocity Then, the cycle restarts. In some books, I read that Energy equation (to provide Density) is solved between steps 2-3, while in other books I found that it is the last step (after step 4). Most likely, something is missing in my reasoning. Could someone help me, please? Thank you in advance, Tommy M. |
Comparing residuals of momentum and energy equation | skarma | FLUENT | 4 | November 25, 2017 22:03 |
Error in computing Energy equation | faab | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 13:04 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pyrolisis energy equation | yaqb | OpenFOAM Programming & Development | 0 | May 22, 2014 17:25 |
problem on energy and flow equation solving separately | preetam69 | FLUENT | 2 | July 30, 2013 21:08 |
