different results by version 2.3.0 vs 3.0.0
Old   October 24, 2018, 06:37
Default different results by version 2.3.0 vs 3.0.0
Not applicable
kagen816 is on a distinguished road
Dear Foamers,
I am calculating a case of cylinder flow. I am using DES(SA) in OpenFoam 3.0.0 but can't get a good result. There is a very interesting thing I found: I used the same grids, boundary conditions , fvsolution, fvscheme in openfoam2.3.0 and then I got a good result. I want to know why? I want to know the reason because I want to use WALE model in 3.0.0 which can not use in 2.3.0.
my question:
1. what cause the difference between version 2.3.0 and 3.0.0?
2. Can I get the same DES results in 3.0.0 as in 2.3.0 by adjusting some thing?
BEST
kagen816 is offline   Reply With Quote
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 20:49
OpenFOAM version 2.3.0 RPM on SuSE linux 12.2 gautami OpenFOAM Installation 2 May 25, 2014 11:37
Adding temperature to interFoam, openFOAM version 2.3.0 abdessamad OpenFOAM Programming & Development 0 May 9, 2014 08:27
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 02:54
How can i uninstall new version of OF shipman OpenFOAM Installation 5 August 12, 2013 04:01
