solidCylinder (solidParticle) positions error |
October 20, 2017, 17:50 |
Joaquín Neira
Rep Power: 8 |
I am a new OpenFOAM user (and new in the forums) with almost zero experience in C++ coding. I've been trying to run a solver based on particle tracking SolidCylinderFoam (wirtten by Jelena Andric in OF1.5), which uses a new class called solidCylinder and solidCylinderCloud that are the same as solidParticle and solidParticleCloud, but with a very small change (no properties are changed). I had some issues to make it work on OF5.0 but finally it compiled without problems. Now, the problem comes when I run the test case, which should track 2 particles: Code:
Create time Create mesh for time = 0 Reading field U Reading field rho Reading field nu Reading environmentalProperties Creating particle cloud --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 19 the punctuation token ')' file: /home/usuario4/Joaquin/OpenFOAM/OpenFOAM-5.0/solidParticleFoam/box/0/lagrangian/defaultCloud/positions at line 19. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5.x | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class Cloud<solidCylinder>; location "0"; object positions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( (1e-2 9e-2 0.05 ) 0 (2e-2 9e-2 0.05 ) 0 ) // ************************************************************************* // Code:
2 ( 2.0e-3 2.0e-3 ) Code:
2 ( (1.7e-1 0 0) (1.7 0 0) ) Code:
rhop rhop [ 1 -3 0 0 0 0 0] 1000; e e [ 0 0 0 0 0 0 0] 0.8; mu mu [ 0 0 0 0 0 0 0] 0.2; Thanks in advance |
October 23, 2018, 02:35 |
[solidParticleInterFoam] solidParticleDamBreak positions error
Ludo Masci
Rep Power: 7 |
Hi Joaquim,
I found the same error trying to implement a lagrangian part into the interFoam solver. I haven't solved the issue yet. Could you please keep posted if you found solutions? Here is the log file I got. Code:
Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Reading g Reading hRef Calculating field g.h No MRF models present No finite volume options present DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 20 the punctuation token ')' file: /home/jlh/OpenFOAM/jlh-5.0/run/solidParticleDamBreak/0/lagrangian/defaultCloud/positions at line 20. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Last edited by lumasci; October 23, 2018 at 02:39. Reason: mistakenly validated the post |
October 23, 2018, 08:00 |
Vince
Rep Power: 9 |
I have never used these solvers but I bet this has to do with barycentric tracking introduced in OF-5: https://cfd.direct/openfoam/free-sof...tric-tracking/ The input file to locate the different particles will necessarily differ from older OF versions, thus the error. You could browse through older posts dealing with barycentric tracking for more details. Thanks, Vincent |
November 7, 2018, 11:09 |
test case barycentric tracking - particle in Eulerian
Ludo Masci
Rep Power: 7 |
Thanks for the reply. I understand better why the command "position" can't work now anymore. I didn't manage to solve my issue, though. Having a test case would help visualize how to implement this "new" tracking function. Is someone aware of an existing test case using the barycentric function? (Even better as a tutorial.) My aim to add particles to an Eulerian phase. Thanks. Ludo |
error, positions, solidcylinder, solidparticle, solidparticlecloud |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
