Choosing a solver.
I am a complete beginner. I am trying so simulate water flow in a simple y pipe whose branches are 90° apart. I have already drawn the geometry in Salome and exported it to Openfoam in unv format. I used ideasUnvToFoam to make it openFoam compatible. I tried using icoFoam but I got errors. I suspect it's the boundary conditions in the u and p files. Anyone with a tip on how to go about this? Thanks
as in most cases when you want a helpful answer, provide more details. We know you tried icoFoam but failed, but what did the error message say? Do you try to simulate a transient flow or a steady one? Which boundary conditions do you use? Which fvSolution settings and which fvSchemes settings? If you provide at least these infos you might get a more detailed answer and in a less amout of time. Either upload your files as an attachment or post their content in [code*][*/code] brackets (without the *). |
Thanks Robert.
I have attached a screenshot of the error message. I tried to simulate a transient flow. My boundary conditions were; Pressure Boundary Conditions(Inlet- fixedValue, Outlet-fixedValue, walls-zeroGradient) and Velocity Boundary Conditions(Inlet-pressureInletVelocity, Outlet-zeroGradient, Walls-fixedValue). As for the fvsolution and fvSchemes settings, what settings are appropriate for my case? I run my simulation with the fvsolution and fvschemes as copied directly from the cavity case in icoFoam. Any help or correction will be appreciated. I am an undergrad doing my final year project and I need to use openfoam |
Your screenshot is not shown here. You can use command icoFoam > log.Error and this will create a file named as log.Error. You can post that error in here then we can see your problem. I suspect that your problem is related to the boundary file located in the constant/polyMesh directory. After you converged your mesh into the OpenFOAM format, you should look into your boundary file. Name of your boundaries in 0/U and 0/p must be same with the boundary file in the constant directory.
Batu |
i can't see you screenshot, but we can start with the the more obvious parts: Pressure boundary condition: Inlet shoud be zeroGradient, while the outlet ist fixedValue. Velocity: For your outlet try: Code:
outlet |
Hello guys,
Sorry for not getting back earlier but Robert's solution worked. I had edited the boundary file incorrectly. Thanks a lot |
