Report "negative initial temperature T0" when using compressibleInterFoam
Like Tree3Likes
  • 3 Post By The King
Old   September 28, 2018, 23:22
Default Report "negative initial temperature T0" when using compressibleInterFoam
Zhanyuan Wang
Zhanyuan Wang is on a distinguished road
I m a new learner of OF and I m trying to simulating supercritical (high-temperature and high-pressure) spray characteristics using compressibleInterFoam. When i run the case, it always broke down after only a few steps and report like that:
[0]
[4] [1]
[4]
[4] --> FOAM FATAL ERROR:
[4] Negative initial temperature T0: -1496.0858
[4]
[4] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam:: specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam ::icoPolynomial<Foam::specie> >, Foam::sensibleInternalEnergy>]
[4] in file /home/wzy/OpenFOAM/OpenFOAM-5.x/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54.
Because i m a new learner, i just simply copy most part of the tutorial case and modified some details. The tutorial case uses laminar model, const thermo type, hConst transport type and perfectFuild model and i changed them to LES model, polynomial, hPolynomial and icoPolynomial. I dont know if it caused the problem. Did i set wrong BC values, wrong fvSchemes or wrong time steps? Is there any problem with my mesh? Need i modify the source code of this solver?
My case is in the attachment and I will be grateful very very very much for anyone who can offer help.
Zhanyuan Wang is offline   Reply With Quote
Old   November 14, 2018, 03:58
Arnout
The King is on a distinguished road
Hi!
did you found a solution? Got the same...
The King
The King is offline   Reply With Quote
Old   November 14, 2018, 04:13
Arnout
Found the answwer in on this forum. I changed the pressure from 0 (guage) to 1atm (1e5) and the p_rgh file since the case is compressible and than you need absolute pressures in the calculations.
Simulation running without any problem now.
The King
jiejie, febriyan91 and sk_malladi like this.
compressibleinterfoam, negative temperature, spray injection, wrong solution
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 21:33
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
