foam-extend solver steadyCompressibleMRFFoam stops with no error |
November 15, 2018, 05:16 |
Martin
Rep Power: 7 |
steadyCompressibleMRFFoam is solver which is part of foam-extend-4.0
I tried to use it with standard tutorial mixerVessel2D, but solver stops after first time step and there is no error mentioned in Terminal. However after some time I do get message from Ubuntu that solver had stopped. Here is all I get from Terminal: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-fdc2bc58d4a4 Exec : steadyCompressibleMRFFoam Date : Nov 15 2018 Time : 09:54:27 Host : dom1221-VirtualBox PID : 9825 CtrlDict : "/home/dom1221/OpenFOAM/fe40_cases/steadyCompressibleMRFFoam/mixerVessel2D/system/controlDict" Case : /home/dom1221/OpenFOAM/fe40_cases/steadyCompressibleMRFFoam/mixerVessel2D nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating MRF for cell zone rotor. rpm = 1000 Excluded patches: 0() Starting time loop Time = 1 BiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.00117246, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.00117498, No Iterations 1 BiCGStab: Solving for p, Initial residual = 1, Final residual = 0.00551125, No Iterations 12 time step continuity errors : sum local = 0.000504934, global = -1.51958e-05, cumulative = -1.51958e-05 BiCGStab: Solving for p, Initial residual = 0.518711, Final residual = 0.00493365, No Iterations 11 time step continuity errors : sum local = 0.000436119, global = -1.34227e-05, cumulative = -2.8 |
foam-extend-4.0, rotation, steadycompressiblemrffoam, turbomachinery |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
