Non-uniform Unsteady Periodic Inlet Boundary Conditions in OpenFOAM
I am trying to simulate a turbine blade with unsteady incoming wakes in OpenFOAM. For the same, I want to use non-uniform inlet profiles of totalPressure, totalTemperature, pressureDirectedInletVelocity, fixedValue TKE and fixedValue omega, which are from high-fidelity simulations and are representative of a wake downstream of a turbine blade. Using these profiles saves computation time. These profiles should however be able to move in the pitchwise direction with a user defined velocity and they should also be periodic in the pitchwise direction. Can anyone please provide suggestions on how to get started with this problem. Attached is a simple sketch Thank you. Regards, Harshal p { margin-bottom: 0.25cm; line-height: 120%; } |
1 Attachment(s)
