simpleFoam no MRF model present
Old   February 24, 2018, 18:59
Default simpleFoam no MRF model present
Sean Gorry
Sean95 is on a distinguished road
I am trying to run a simpleFoam model but I am getting a no MRF models present, what could be causing this? The finite volume options present error can be solved by adding a fvoptions file.
Also how do you set the convergence criteria?
Any help would be great
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 500 steps.
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
bounding k, min: 0 max: 0 average: 0
bounding omega, min: 0 max: 0 average: 0
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
decayControl false;
kInf 0;
omegaInf 0;
No MRF models present
No finite volume options present
Sean95 is offline   Reply With Quote
Old   February 25, 2018, 18:19
Sean Gorry
I managed to solve the finite volume issue, but now the solver just stops?
Create time
Reading field p
Reading field U
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
decayControl false;
kInf 0;
omegaInf 0;
Creating finite volume options from "system/fvOptions"
Selecting finite volume options type limitVelocity
Source: Fluid_Domain
- selecting cells using cellZone fluid_domain
- selected 1570686 cell(s) with volume 5.18396e-06
Then the prompt line appears
Old   November 26, 2018, 07:17
Vidyuth
vidyuth is on a distinguished road
Can i know how you managed to solve the "No fvoption error"
vidyuth is offline   Reply With Quote
Old   November 26, 2018, 07:18
Default Can you help me with this?
Vidyuth
Create time
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon)" tolerance 0.001
Reading field p
Reading field U
RAS
turbulence on;
RASModel kOmegaSST;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::IncompressibleTurbulenceModel<Foam::transpo rtModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transpor tModel> >::F2() const at ??:?
#6 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::IncompressibleTurbulenceModel<Foam::transpo rtModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transpor tModel> >::F23() const at ??:?
#7 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::IncompressibleTurbulenceModel<Foam::transpo rtModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transpor tModel> >::correctNut() at ??:?
#8 ? in "/home/cfdlab2/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt64Opt/bin/simpleFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? in "/home/cfdlab2/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt64Opt/bin/simpleFoam"
Floating point exception (core dumped)
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Using a new implemented viscosity model with simpleFoam TemC OpenFOAM Running, Solving & CFD 6 March 8, 2017 03:07
Problem with using MRF Model for verical axis wind turbine Model rgunjegaonkar@gmail.com FLUENT 15 March 16, 2016 04:28
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
BC for MRF simpleFoam student666 OpenFOAM Running, Solving & CFD 2 July 30, 2014 13:20
