Fatal IO Error: "method" not found in fv.schemes
Like Tree11Likes
  • 4 Post By pete20r2
  • 1 Post By Archoncomando
  • 6 Post By pete20r2
Old   December 14, 2018, 09:24
Default Fatal IO Error: "method" not found in fv.schemes
Florian
Archoncomando is on a distinguished road
Hello, i've only started using OpenFOAM a few days back so i'm still fairly new to the whole process.
I'm working on a bachelor's thesis regarding a hydrofoil wing profile. My thesis is based in large part on several other students work over the last 4 years.
I'm currently struggling with getting through a complete InterFoam simulation without fatal errors.
The current one reads like this:
"method" not found in dictionary "mnt/c/.../system/fv.schemes ./mnt/c/.../fv.schemes.wallDist"
I'm not sure what is being referred to as method.
My fv.schemes file looks like this:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         localEuler rDeltaT;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)   Gauss linearUpwind grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div(phi,k)      Gauss upwind;
    div(phi,omega)  Gauss upwind;
    div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
I'm working with the current OpenFOAM release version. Most of the work done before me is however made on OpenFoam 2.3. I've already adressed a lot of the issues with the changes but i'm really breaking my head on this one.
Or would you recommend just going back to OpenFOAM 2.3 instead of trying to adapt the project to 4+? Also is there a good source for file templates for the current version?
I'd be very grateful about some insights or Ideas on how to adress this.
Thanks in Advance
Florian
Archoncomando is offline   Reply With Quote
Old   December 14, 2018, 23:20
Peter Baskovich
pete20r2 is on a distinguished road
Add to fvShemes
wallDist
method meshWave;
galoisati, esma, Xiutao and 1 others like this.
pete20r2 is offline   Reply With Quote
Old   December 15, 2018, 07:25
Florian
Hey there thanks for the quick fix! Did you just do that off the top of your head or is there some source for templates / guidelines what each file needs to include?
Is the fix for this issue similarly easy? OpenFOAM is now complaining about not having a pcorrfinal in the fvSolution.solvers.
Thanks again for the quick help
Pavlord likes this.
Old   December 15, 2018, 09:47
Peter Baskovich
Hello again Florian, welcome, I just noticed you are new here
Free fish is good but catching them yourself is better huh.
Unfortunately, I could answer that off the top of my head lol.
But here is how I figured it out the first time.
There are lots of clues in the errors OF generates, unless something has gone very wrong the errors should guide you to a solution.
Notice how the file it's reading is called fvSchemes and it's looking for something called wallDist inside? The other clue is it's trying to read "method" from the fvSchemes.wallDist dictionary.
So we make an entry in fvSchemes for wallDist with an entry "method", but what is an appropriate value to ascribe to "method"?
There is a technique we call the 'banana' and it works for all variables, it's useful for dictionaries where the value needs to be some keyword but you don't know what your options are. Just set it to 'banana' or anything that is unlikely to be a valid input and run the solver.
wallDist
method banana;
OF will stop running and give you a list of options that are actually valid.
You can try it yourself but I ran it here just to show:
Selecting patchDistMethod banana
--> FOAM FATAL ERROR:
Unknown patchDistMethod type banana
Valid patchDistMethod types :
3
Poisson
advectionDiffusion
meshWave
Try it out on your fvSolutions problem
I find I end up here (direct to the meshWave entry):
Extended Code Guide - meshWave
The User Guide:
http://foam.sourceforge.net/docs/Gui...erGuide-A4.pdf
The wiki:
https://openfoamwiki.net/index.php/Main_Page
And of course these forums (you should probably post in the "OpenFOAM Running, Solving & CFD" subforum next time, more likely to get attention there )
Finally,
I know it's really exciting to get up and running and go straight for solving your problem but I can't recommend the tutorials enough.
They are included in the OF package and sorted by physics and solver.
Run some of them that have similar features to your problem and dig around the setup files ( steal things that work ). Find examples using the same solver, same boundary conditions, same mesh type, similar physics etc. Doesn't have to be all at once, just grab the bits you need from each.
johnkh, tonnykz, tmik and 3 others like this.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 16:16
fireFoam.1.7.x_0.4 compilation error !link OpenFOAM Installation 9 December 24, 2012 04:15
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
