July 29, 2019, 12:43 |
OpenFOAM simulation using DME
Yujuan Luo
Rep Power: 6 |
Hello FOAMers,
I'm doing combustion simulation using OpenFOAM. The fuel is DME, and the mechanism is Zhao's mechanism(Zhao Z, Chaos M, Kazakov A, Dryer FL. Thermal decomposition reaction and a comprehensive kinetic model of dimethyl ether. Int J Chem Kinet 2008;40:1–18. doi:10.1002/kin.20285.). The problem is that when I use the original mechanism and thermo file downloading from the website, there are always errors related to chemistryReader. Then I deleted some redundant numerical flags in last column of the thermo file, as well as some blanks in mechanism file. Then the errors disappear. However, the new problem is that the program always crashes at the first step(errors are attached below), specifically, combustion->correct(). I also tested the mechanism with the reactingFoam, there are still errors. When I substitute the mechanism file with others (like gri30), there is no problem. So I am just wondering whether the mechanism and thermo files are not read correctly. Can anyone who have succeeded in DME simulation using OpenFOAM share these two files with me? Thanks a lot. error information: Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model laminar<psiChemistryCombustion> Selecting chemistry type { chemistrySolver EulerImplicit; chemistryThermo psi; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader chemkinReader chemistryModel: Number of species = 55 and reactions = 290 using integrated reaction rate H H2 CH2 CH2(S) CH3 O CH4 OH H2O C2H C2H2 C2H3 CO N2 C2H4 HCO C2H5 CH2O C2H6 CH2OH CH3O O2 CH3OH HO2 H2O2 HCCO CH2CO HCCOH CH2HCO CH3CO CO2 CH3HCO OCHO CH3CHOH C2H4OH CH3CH2O CH3OCH2 HCOOH CH3OCH3 C2H5OH HOCH2O CH3OCO CH3OCHO CH3OCH2O CH3OCH2OH OCH2OCHO HOCH2OCO HOC2H4O2 CH3OCH2O2 CH2OCH2O2H CH3OCH2O2H HO2CH2OCHO O2CH2OCH2O2H AR HE Reading field rho Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Creating field dpdt Creating field kinetic energy K Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - applying source at time 0.1 for duration 0.4 - selecting cells using cellSet ignitionCells - selected 0 cell(s) with volume 0 Selecting radiationModel fvDOM Selecting absorptionEmissionModel greyMeanAbsorptionEmission Selecting scatterModel none Selecting sootModel none fvDOM : Allocated 8 rays with average orientation: Caching div fvMatrix... I0 : omega : 1.570796327 I1 : omega : 1.570796327 I2 : omega : 1.570796327 I3 : omega : 1.570796327 I4 : omega : 1.570796327 I5 : omega : 1.570796327 I6 : omega : 1.570796327 I7 : omega : 1.570796327 Courant Number mean: 0.0137639165 max: 8.769733406 PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 0.0009414443574 max: 0.5998449662 deltaT = 6.83994528e-06 Time = 6.83995e-06 ************************************************* diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 5.021638158e-06, No Iterations 9 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 6.148268069e-06, No Iterations 9 [3] #0 Foam::errorrintStack(Foam::Ostream&)at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 at ??:? [2] #2 at ??:? [3] #2 at ??:? [0] #2 in "/lib/x86_64-li in "/lib/x86_64-linux-gnunux-gnu/libc.so.6" [2] #3 /libc.so.6" [3] #3 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 at makeReactions.C:? [1] #4 at makeReactions.C:? [2] #4 Foam::chemistryModel<FoamsiChemistryModel, Foam::chemistryModel<FoamsiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<FoamerfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >mega(Foam::Reaction<Foam::sutherlandTransport<F oam::species::thermo<Foam::janafThermo<Foamerfec tGas<Foam::specie> >, Foam::sensibleEnthalpy> > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const at makeReactions.C:? [0] #7 Foam::chemistryModel<FoamsiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<FoamerfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve(double) at ??:? [1] #8 Foam::combustionModels::laminar<Foam::combustionMo delssiChemistryCombustion>::correct() at ??:? [1] #9 at ??:? [2] #9 at ??:? [3] #9 at ??:? [0] #9 [1] at ~/OpenFOAM/yujuan-2.3.1/applications/solver/DCFoam/YEqn.H:15 [1] #10 [2] at ~/OpenFOAM/yujuan-2.3.1/applications/solver/DCFoam/YEqn.H:15 [2] #10 __libc_start_main__libc_start_main in "/lib/x86_64-linux-gnu in "/lib/x86_64-linux-gnu/libc./libc.so.6" so.6" [1] #11 [2] #11 [3] at ~/OpenFOAM/yujuan-2.3.1/applications/solver/DCFoam/YEqn.H:15 [3] #10 __libc_start_main[0] at ~/OpenFOAM/yujuan-2.3.1/applications/solver/DCFoam/YEqn.H:15 [0] #10 __libc_start_main[1] at ??:? [yujuan:19833] *** Process received signal *** [yujuan:19833] Signal: Floating point exception (8) [yujuan:19833] Signal code: (-6) [yujuan:19833] Failing at address: 0x3e800004d79 [2] at ??:? [yujuan:19834] *** Process received signal *** [yujuan:19833] [ 0] [yujuan:19834] Signal: Floating point exception (8) [yujuan:19834] Signal code: (-6) [yujuan:19834] Failing at address: 0x3e800004d7a /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fda79c0c4b0] [yujuan:19833] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fda79c0c428] [yujuan:19833] [ 2] [yujuan:19834] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f1e41be64b0] [yujuan:19834] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fda79c0c4b0] [yujuan:19833] [ 3] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f1e41be6428] [yujuan:19834] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f1e41be64b0] [yujuan:19834] [ 3] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcspecie.so(+0x227cbe)[0x7fda7e081cbe] [yujuan:19833] [ 4] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcspecie.so(+0x227cbe)[0x7f1e4605bcbe] [yujuan:19834] [ 4] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam14chemistryMode lINS_17psiChemistryModelENS_19sutherlandTransportI NS_7species6thermoINS_11janafThermoINS_10perfectGa sINS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5omega ERKNS_8ReactionISC_EERKNS_5FieldIdEEddRdSM_RiSM_SM _SN_+0x17e)[0x7fda7c81e81e] [yujuan:19833] [ 5] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam14chemistryMode lINS_17psiChemistryModelENS_19sutherlandTransportI NS_7species6thermoINS_11janafThermoINS_10perfectGa sINS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5omega ERKNS_8ReactionISC_EERKNS_5FieldIdEEddRdSM_RiSM_SM _SN_+0x17e)[0x7f1e447f881e] [yujuan:19834] [ 5] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam13EulerImplicit INS_14chemistryModelINS_17psiChemistryModelENS_19s utherlandTransportINS_7species6thermoINS_11janafTh ermoINS_10perfectGasINS_6specieEEEEENS_16sensibleE nthalpyEEEEEEEE5solveERNS_5FieldIdEERdSJ_SJ_SJ_+0x 3a4)[0x7f1e4482d314] [yujuan:19834] [ 6] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam13EulerImplicit INS_14chemistryModelINS_17psiChemistryModelENS_19s utherlandTransportINS_7species6thermoINS_11janafTh ermoINS_10perfectGasINS_6specieEEEEENS_16sensibleE nthalpyEEEEEEEE5solveERNS_5FieldIdEERdSJ_SJ_SJ_+0x 3a4)[0x7fda7c853314] [yujuan:19833] [ 6] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveI NS_12UniformFieldIdEEEEdRKT_+0x5c2)[0x7f1e4484bf92] [yujuan:19834] [ 7] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveI NS_12UniformFieldIdEEEEdRKT_+0x5c2)[0x7fda7c871f92] [yujuan:19833] [ 7] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveE d+0x32)[0x7f1e4484c3a2] [yujuan:19834] [ 8] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveE d+0x32)[0x7fda7c8723a2] [yujuan:19833] [ 8] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDccombustionModels.so(_ZN4Foam16combustionMo dels7laminarINS0_22psiChemistryCombustionEE7correc tEv+0x243)[0x7f1e43f41173] [yujuan:19834] [ 9] in "/lib/x86_64-linux-gnu/libc.so.6" DCFoam[0x4233ad] [yujuan:19834] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f1e41bd1830] [yujuan:19834] [11] DCFoam[0x421199] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDccombustionModels.so(_ZN4Foam16combustionMo dels7laminarINS0_22psiChemistryCombustionEE7correc tEv+0x243)[0x7fda7bf67173] [yujuan:19833] [ 9] DCFoam[0x4233ad] [yujuan:19833] [10] [3] #[yujuan:19834] *** End of error message *** 11 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fda79bf7830] [yujuan:19833] [11] DCFoam[0x421199] [yujuan:19833] *** End of error message *** in "/lib/x86_64-linux-gnu/libc.so.6" [0] #11 [3] at ??:? [yujuan:19835] *** Process received signal *** [yujuan:19835] Signal: Floating point exception (8) [yujuan:19835] Signal code: (-6) [yujuan:19835] Failing at address: 0x3e800004d7b [yujuan:19835] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f043eb5e4b0] [yujuan:19835] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f043eb5e428] [yujuan:19835] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f043eb5e4b0] [yujuan:19835] [ 3] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcspecie.so(+0x227cbe)[0x7f0442fd3cbe] [yujuan:19835] [ 4] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam14chemistryMode lINS_17psiChemistryModelENS_19sutherlandTransportI NS_7species6thermoINS_11janafThermoINS_10perfectGa sINS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5omega ERKNS_8ReactionISC_EERKNS_5FieldIdEEddRdSM_RiSM_SM _SN_+0x17e)[0x7f044177081e] [yujuan:19835] [ 5] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam13EulerImplicit INS_14chemistryModelINS_17psiChemistryModelENS_19s utherlandTransportINS_7species6thermoINS_11janafTh ermoINS_10perfectGasINS_6specieEEEEENS_16sensibleE nthalpyEEEEEEEE5solveERNS_5FieldIdEERdSJ_SJ_SJ_+0x 3a4)[0x7f04417a5314] [yujuan:19835] [ 6] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveI NS_12UniformFieldIdEEEEdRKT_+0x5c2)[0x7f04417c3f92] [yujuan:19835] [ 7] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveE d+0x32)[0x7f04417c43a2] [yujuan:19835] [ 8] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDccombustionModels.so(_ZN4Foam16combustionMo dels7laminarINS0_22psiChemistryCombustionEE7correc tEv+0x243)[0x7f0440eb9173] [yujuan:19835] [ 9] DCFoam[0x4233ad] [yujuan:19835] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f043eb49830] [yujuan:19835] [11] DCFoam[0x421199] [yujuan:19835] *** End of error message *** [0] at ??:? [yujuan:19832] *** Process received signal *** [yujuan:19832] Signal: Floating point exception (8) [yujuan:19832] Signal code: (-6) [yujuan:19832] Failing at address: 0x3e800004d78 [yujuan:19832] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fcc9a9184b0] [yujuan:19832] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fcc9a918428] [yujuan:19832] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fcc9a9184b0] [yujuan:19832] [ 3] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcspecie.so(+0x227cbe)[0x7fcc9ed8dcbe] [yujuan:19832] [ 4] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam14chemistryMode lINS_17psiChemistryModelENS_19sutherlandTransportI NS_7species6thermoINS_11janafThermoINS_10perfectGa sINS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5omega ERKNS_8ReactionISC_EERKNS_5FieldIdEEddRdSM_RiSM_SM _SN_+0x17e)[0x7fcc9d52a81e] [yujuan:19832] [ 5] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZNK4Foam13EulerImplicit INS_14chemistryModelINS_17psiChemistryModelENS_19s utherlandTransportINS_7species6thermoINS_11janafTh ermoINS_10perfectGasINS_6specieEEEEENS_16sensibleE nthalpyEEEEEEEE5solveERNS_5FieldIdEERdSJ_SJ_SJ_+0x 3a4)[0x7fcc9d55f314] [yujuan:19832] [ 6] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveI NS_12UniformFieldIdEEEEdRKT_+0x5c2)[0x7fcc9d57df92] [yujuan:19832] [ 7] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDcchemistryModel.so(_ZN4Foam14chemistryModel INS_17psiChemistryModelENS_19sutherlandTransportIN S_7species6thermoINS_11janafThermoINS_10perfectGas INS_6specieEEEEENS_16sensibleEnthalpyEEEEEE5solveE d+0x32)[0x7fcc9d57e3a2] [yujuan:19832] [ 8] /home/yujuan/OpenFOAM/yujuan-2.3.1/platforms/linux64GccDPOpt/lib/libSWQDccombustionModels.so(_ZN4Foam16combustionMo dels7laminarINS0_22psiChemistryCombustionEE7correc tEv+0x243)[0x7fcc9cc73173] [yujuan:19832] [ 9] DCFoam[0x4233ad] [yujuan:19832] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fcc9a903830] [yujuan:19832] [11] DCFoam[0x421199] [yujuan:19832] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 19833 on node yujuan exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
July 30, 2019, 10:12 |
Adhiraj
Rep Power: 15 |
Does the mechanism contain any fall-off type reaction in TROE form with some coefficients (Ts, Tsss) as zero?
Have you tried running tests in chemFoam with this mechanism? |
July 30, 2019, 10:54 |
#3 | |
Yujuan Luo
Rep Power: 6 |
! Wang et al., JPC A 107:11414 (2003) CH3+CH3(+M) = C2H6(+M) 2.277E+15 -0.69 1.7486E+02 LOW/8.054E+31 -3.75 9.816E+02/ TROE/0.0 570.0 0.0 1.E+30/ H2O/5/ CO/2/ CO2/3/ Since Ts is set to be zero, the program just gets an error of floating pointing exception. I wonder if I should change the value of Ts to a very small value, like 1E-31? Or I should use substitutes for this reaction? |
July 30, 2019, 12:33 |
Adhiraj
Rep Power: 15 |
openfoam dme |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFoam 4.1: interDyMFoam LES Simulation for hydro turbine in river | pi__sec | OpenFOAM Running, Solving & CFD | 13 | July 19, 2017 04:08 |
running multiple parallel cases in openfoam slows the simulation | kkpal | OpenFOAM Running, Solving & CFD | 2 | August 21, 2015 11:08 |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 09:46 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
