[Sponsors] | |||||
Zander Meiring
Rep Power: 9 ![]() |
Good day all,
I am modelling an axial flow fan, and am experimenting with different turbulence models. High on my interest is that of the k-omega sst model. I have searched around, but mostly have found old and often conflicting views on the correct way to implement the k-omega sst model for a low-Re type simulation (solving through boundary layer). k is simple enough to set to a low value, but omega I've heard recomendations to use omegaWallFunction or setting it to a large, constant value ( omega = (2*nu)/(C_w2*y_1^2) ). Which is the more correct implimentation for solving through the boundary layer (y+<1). And if the former, what value is used in the value field? As for nut, I've seen recommendation to use nutSpalartAllmarasWallFunction, nutWallFunction, calculated or 1e-12. And if using any of the wall funcs or calculated, what would be the value once again? Thanks! |
Hi Zander Meiring,
I'm using the same turbulent model at the moment, applying low-Re function. I found a discussion from https://www.researchgate.net/post/Sh..._wall_function It seems that omegaWallFunction is suitable for both low and high Re.The condition based the blending of viscous and log layer. For nut, in fact, there is a nutLowReWallFuntion. Code:
tmp<scalarField> nutLowReWallFunctionFvPatchScalarField::calcNut() const
return tmp<scalarField>(new scalarField(patch().size(), 0.0));
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wall treatment with OpenFOAM | roby | OpenFOAM Running, Solving & CFD | 48 | May 28, 2021 12:38 |
| Turbulence Near wall Treatment: can standard treatment be used for y+ between 1 to 5? | mohibanwar | FLUENT | 9 | August 30, 2015 02:11 |
| Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
| Solver Yplus of Automatic wall treatment | justjhy | CFX | 2 | May 4, 2013 08:19 |
| nutUSpaldingWallFunction - nutSpalartAllmarasWallFunction - Automatic Wall Treatment | dogan | Main CFD Forum | 0 | March 5, 2013 08:40 |
