OpenFoam change library
Old   January 23, 2019, 17:38
Default OpenFoam change library
Christophk
syntex is on a distinguished road
I am trying to compute on a high performance cluster, since my local devices performance is not good enough. My problem is, that I changed a ".c"- file in the soucre/fvOptions folder on my local machine to do my simulation. I can't change the folder one the high performance cluster, because it is set to read-only.
I have access to the a home folder and to the $FOAM_RUN - directory, which I can change like I want.
Is there any way I can set up my simulation, so that it uses an own class, with changed ".C" or ".H"-Files or even create my own class with the run-folder, where I have access to, which will be used by fvoptions? The simulation has to compile this code as well.
It would be nice, if someone could help me.
syntex is offline   Reply With Quote
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Openfoam Library access cmh OpenFOAM Programming & Development 1 July 22, 2013 05:43
