[Sponsors] | |||||
madz
Rep Power: 9 ![]() |
I'm running a 2D turbulent compressible rae2822 airfoil simulation at mach no 0.6 using rhoCentralFoam solver.
The simulation ran fine and i got accurate pressure and velocity contours as well as able to plot Cp vs x/c using paraview. But the wallShearStress and the values of the coefficients are way off than the standard results. To calculate forces and force coefficients i used the standard code in the controlDict. Another thing i want to know is whether y+ values effect the forces.because im getting different values of forces coefficient for different y+ values. controlDict.txt |
Zander Meiring
To get accurate drag, it is necessary to resolve the boundary layer as a wall function will not give a good enough velocity gradient to accurately determine wall shear. As such, y+ is a very important metric for determining wall shear, and by extension, drag. If you can afford it, I would ensure that the y+ along the entire wall is at or less than 1, and that minimal to no cell grading is used for the first couple of cells. But it is also a difficult task to get accurate drag coefficents for aerofoils, and I struggled correlating numerical and experimental in my undergrad thesis when investigating a naca foil in transitional conditions.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Force and Force Coefficient | ata | OpenFOAM Post-Processing | 9 | August 18, 2021 14:44 |
| getting wrong forces and force coefficients in openfoam | maddy11 | OpenFOAM | 2 | January 23, 2019 02:09 |
| ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 12:12 |
| Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 11:42 |
| SonicFoam - Forces, viscous force too big? | Kryo | OpenFOAM Running, Solving & CFD | 1 | September 15, 2012 15:33 |
