[Sponsors] | |||||
Adithya Gurumurthy
Rep Power: 10 ![]() |
Hello Foamers!
I have incorporated y+ calculations in my code (following a similar procedure as in http://www.tfd.chalmers.se/~hani/kur..._Xu_Report.pdf ). However, this calculates y+ only in cells near the boundary of a wall patch. I would like to calculate y+ values in cells that are, say 4-5 layers from the wall patch. Could someone help me out with this? Thanks |
Xavier Lamboley
Rep Power: 12 ![]() |
Hi raptorishungry,
I have myself implemented functionObjects which calculate uStar on the wall patch, and uPlus and yPlus in the whole field on this thread. However, uPlus and yPlus use the average uStar on the wall, and should be using the value on nearest patch face. If you have any idea on this topic this would be welcome
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
| Questions on dynamicTopoFvMesh | danvica | OpenFOAM Running, Solving & CFD | 80 | April 16, 2019 17:58 |
| Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
| snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 20:18 |
| assign values to selected cells | zxj160 | OpenFOAM Pre-Processing | 4 | June 29, 2012 13:17 |
