error is shown while solving problem using icoFoam solver
Old   February 4, 2019, 17:43
Default error is shown while solving problem using icoFoam solver
Pawan Sharma
pawansharma is on a distinguished road
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: /home/pawan123/OpenFOAM/tutorials/incompressible/icoFoam/cavity/ellipse/system/data.solverPerformance.p at line 0.
From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::doubleScalar&)
in file lnInclude/Scalar.C at line 93.
FOAM exiting
pawansharma is offline   Reply With Quote
Old   February 6, 2019, 05:25
Robert
RobertHB is on a distinguished road
It's what it says. In the named file, line 0, there should be a numer but instead there is the string nan. So whatever you are trying to do is currently not working.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
