February 19, 2019, 11:47 |
overset mesh - collision of mesh
Max
Rep Power: 14 |
Hallo,
I basically try to simulate a stone falling into water using the overset mesh methode and OpenFOAM v1812 with the solver overInterDyMFoam. I used the floatingBody tutorial and modified it. The simulation works fine untill the the "stone" (overset patch) hits the ground (boundary of domain). Is there a possibility to allow collision of the patches or to stop the movement of the overset mesh at a certain distance to the boundary? |
February 19, 2019, 16:56 |
Santiago Lopez Castano
Rep Power: 15 |
The question should be: what should the overset region outside of the background mesh be? That is, what should the cells of the inner cells be whenever they go out of the outer domain?
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Overset Mesh error : no startcell found ! | Cris ZC | STAR-CCM+ | 4 | September 9, 2019 10:43 |
Is overset mesh required? | ahildershavn@yahoo.no | OpenFOAM Running, Solving & CFD | 2 | August 4, 2017 03:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
