June 13, 2018, 07:42 |
LPT incompressible fluid
Davide
Rep Power: 7 |
Hi everyone,
I'm a new member of the community. I'm struggling with OpenFOAM to implement a lagrangian particle tracking on an incompressible fluid (i.e. blood cells in blood). I've followed many tutorials online but any of them worked for me. How can I implement LPT in icoFoam? And how can I post-process particles' properties such as their velocity and inducted shear stress? I'm using OpenFOAM 5.0 on OpenSuse 42.2. Thanks a lot, Lighto |
June 13, 2018, 18:53 |
Rodrigo
Rep Power: 16 |
I think that the closest to what you are looking for is the solver DPMFoam. Indeed it is more a 2-way (kinematic) coupling between pimpleFoam + lagrangian particles with option for particle collisions.
The post-processing is quite easy: 1. paraFoam (load all objects) 2. use extractBlock filter to select your particles 3. use glyph filter e.g as spheres, scaled by the diameter and map onto them whatever property available from the list Regarding the shear stress, I don't think there is such a thing for the particles in OF-5.0. May you rather be looking for something as the "immersed boundary" method? You can find an implementation in the foam-extend version, but keep in mind that it will not work efficiently if you want to simulate many particles simultaneously. |
June 14, 2018, 06:57 |
Davide
Rep Power: 7 |
Thank you for the advice. Basically DMPFoam can solve pressure and velocity fields for water and simultanaously inject particles that follow the fluid velocity, is it right? So what I have to do is to specify the properties of the fluid inside trasportProperties and turbulenceProperties.fluid and than replace rho.air, U.air ecc with rho.fluid, U.fluid ecc inside the directory 0/ and the file system/fvSolution?
October 4, 2022, 19:58 |
Edgar Fernando Rey Torra
Rep Power: 3 |
i know it may be a little late but i think this could help future readers that be starting (as me).
there is a very important parameter called stokes number which may tell you if you need to simulate the lagrangian particles or instead (in case the particles have very few mass) you could assume the particles are embed in the fluid so particles velocity is exactly the same as fluids. if this last is your case you could make the simple simulation of the flow on OF and then apply the particle tracking filter on paraview. |
incompressible fluid, lagrangian particles, lpt, openfoam 5.0, opensuse leap |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
derivation for special case for incompressible fluid; condition for v? | Simonee | Main CFD Forum | 0 | March 18, 2014 06:56 |
What is the total energy for incompressible fluid? | Harry Dong | Main CFD Forum | 12 | February 4, 2006 00:55 |
Initial cinditions for incompressible fluid | Vladimir Fuka | Main CFD Forum | 3 | December 23, 2005 10:45 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
