Add P_rgh to solver with P
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 2, 2019, 11:57
Default Add P_rgh to solver with P
Ramin
rmn_990 is on a distinguished road
I have an incompressible case and this case has some problems with pressure outlet bounday condition.
it is just a duct with an velocity inlet and an pressure outlet.
I asked a friend why the outlet works like this and I got this message:
MPPICFoam/DPMFoam are incompressible solvers so you could use the uniformDensityHydrostaticPressure. However this is not as accurate or reliable as using p_rgh for strongly buoyant flows so you could change these solvers to solve for p_rgh or fund this development.
I tried uniformDensityHydrostaticPressure but it didn't work. Now, I want to add p_rgh instead of p in my solver.
Do you have any idea of what should I do?
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
    version 2.0;
    format ascii;
    class volVectorField;
    object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
    inlet
        type fixedValue;
        value uniform (0.5 0 0);
        //phi phi.water;
        //alpha alpha.water;
    outlet
        type zeroGradient;
        type inletOutlet;
        phi phi.water;
        inletValue uniform (0 0 0);
        value uniform (0 0 0);
    upperWall
        type noSlip;
        type inletOutlet;
        phi phi.water;
    walls
        type noSlip;
    sides
        type noSlip;
FoamFile
    version 2.0;
    format ascii;
    class volScalarField;
    object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
    inlet
        type fixedFluxPressure;
        phi phi.water;
        value $internalField;
    outlet
        type fixedValue;
        value uniform 0;;
        //phi phi.water;
        //value $internalField;
    upperWall
        type zeroGradient;
    walls
        type zeroGradient;
        phi phi.water;
    sides
        type zeroGradient;
        phi phi.water;
Last edited by wyldckat; May 1, 2019 at 10:24. Reason: Added [CODE][/CODE] markers
rmn_990 is offline   Reply With Quote
Old   April 2, 2019, 22:39
LeeRuns is on a distinguished road
Dry but why not use the incompressible solvers for you incompressible case?
LeeRuns is offline   Reply With Quote
Old   April 5, 2019, 17:18
Ramin
Thanks for your response. I think I used most of the boundary conditions and none of them works.
What's your suggestion?
Old   May 1, 2019, 10:53
Retired Super Moderator
Bruno Santos
A few quick answers/questions:
  1. In the first post, the boundary condition for "p" at the inlet is wrong:
        inlet
            phi phi.water;
    If the solver is incompressible, then you should not use buoyancy dependent boundary conditions:
        inlet
            type zeroGradient;
  2. Why exactly is your flow is buoyant? What is the mechanism that is making it work that way?
    • I ask this, just in case you were misguided somewhere along the development of your project... perhaps the flow is not buoyant by nature and only the particles are inducing a distortion to the flow?
rmn_990 likes this.
Old   May 1, 2019, 14:36
Ramin
        inlet
            phi phi.water;
        inlet
            type zeroGradient;
Thanks for your response Bruno.
I tried the boundary condition that you proposed and I can see the problem with outlet boundary condition.
Flow is incompressible and the length of the control volume is less than 10cm. Reynolds number is around 10 and 9.81 gravity.
As far as the dimension is small and also Re is low, I thought that maybe we have buoyant flow. I did this simulation with MPPICInterFoam (with one phase) and everything works well because it works with p_rgh.
I am sure that particles don't have any role in this disturbtion becasue I didn't inject any particle at this stage and I just used MPPICFoam solver.
buoyancy, dpmfoam, mppicfoam, openfoam
[waves2Foam] Add user defined gauges in waveFoam Lewis Liang OpenFOAM Community Contributions 3 October 18, 2020 10:32
Is it possible to add massless particles to an incompressible flow at solver level? LauraSumner OpenFOAM Running, Solving & CFD 1 September 30, 2019 17:13
how to modify a solver to add a disturbance goodkid OpenFOAM 2 June 25, 2011 04:35
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
How to add temperature to cavitatingFoam solver chodki-c OpenFOAM 9 September 30, 2010 11:21
