Jinjolee |
May 12, 2019 03:40 |
Originally Posted by hxaxtma
(Post 733349)
I guess this is a highly non Orthogonal mesh - can be found in checkMesh log File
I recommend following settings:
nNonOrthogonalCorrectors 3;
Pressure equation is diverging, therefore set:
relaxationFactors of pressure p 0.3,
U 0.7 and turbulence variables 0.3
Set consistent to no in the Simple Dict
If this is not running and your mesh is OK something is wrong with your BCs
Thanks for your suggestions. I followed your guide and ran again, but the results were still diverging. Below is the log.simpleFoam(I cut it at iteration 9 because I know it wont do good):
Create mesh for time = 0
[AdminPC:07679] 5 more processes have sent help message help-btl-vader.txt / cma-permission-denied
[AdminPC:07679] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
SIMPLE: Convergence criteria found
U: tolerance 0.0001
p: tolerance 0.0001
"(k|omega)": tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
No MRF models present
No finite volume options present
Starting time loop
streamLine streamLines:
automatic track length specified through number of sub cycles : 5
Reading surface description:
yNormal
forces forceCoeffs1:
Not including porosity effects
forceCoeffs forceCoeffs1:
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0.0456653, Final residual = 0.00423798, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.0288288, Final residual = 0.00174395, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.015543, Final residual = 0.000777086, No Iterations 4
GAMG: Solving for p, Initial residual = 1, Final residual = 0.00897626, No Iterations 12
GAMG: Solving for p, Initial residual = 0.00258742, Final residual = 2.44815e-05, No Iterations 9
GAMG: Solving for p, Initial residual = 0.000234184, Final residual = 2.20371e-06, No Iterations 28
GAMG: Solving for p, Initial residual = 3.7742e-05, Final residual = 3.56882e-07, No Iterations 28
time step continuity errors : sum local = 2.33207e-10, global = 1.31804e-11, cumulative = 1.31804e-11
smoothSolver: Solving for omega, Initial residual = 0.0432445, Final residual = 6.84685e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00190103, No Iterations 1
ExecutionTime = 303.55 s ClockTime = 544 s
forceCoeffs forceCoeffs1 write:
Cm = 0.795466
Cd = 1.52038
Cl = -0.00376598
Cl(f) = 0.793583
Cl(r) = -0.797349
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.0616887, Final residual = 0.00374667, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0243984, Final residual = 0.00133365, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.028181, Final residual = 0.00171954, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0119031, Final residual = 0.000116838, No Iterations 12
GAMG: Solving for p, Initial residual = 0.00487985, Final residual = 4.76482e-05, No Iterations 9
GAMG: Solving for p, Initial residual = 0.000448644, Final residual = 4.26444e-06, No Iterations 26
GAMG: Solving for p, Initial residual = 7.1785e-05, Final residual = 6.86387e-07, No Iterations 27
time step continuity errors : sum local = 4.649e-10, global = -3.29865e-11, cumulative = -1.98061e-11
smoothSolver: Solving for omega, Initial residual = 0.0232035, Final residual = 5.38076e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.24792, Final residual = 0.000678387, No Iterations 1
ExecutionTime = 505.78 s ClockTime = 863 s
Cm = -2.58056
Cd = -4.90158
Cl = 0.0861271
Cl(f) = -2.5375
Cl(r) = 2.62362
Time = 3
smoothSolver: Solving for Ux, Initial residual = 0.125752, Final residual = 0.00786615, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.040605, Final residual = 0.00248977, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.0650774, Final residual = 0.00419616, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0235075, Final residual = 0.000216227, No Iterations 12
GAMG: Solving for p, Initial residual = 0.00310908, Final residual = 2.99842e-05, No Iterations 9
GAMG: Solving for p, Initial residual = 0.000296906, Final residual = 2.87985e-06, No Iterations 24
GAMG: Solving for p, Initial residual = 4.76489e-05, Final residual = 4.60334e-07, No Iterations 26
time step continuity errors : sum local = 9.14815e-10, global = 7.63309e-11, cumulative = 5.65248e-11
smoothSolver: Solving for omega, Initial residual = 0.0130879, Final residual = 4.40088e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.115244, Final residual = 0.000442352, No Iterations 1
ExecutionTime = 711.59 s ClockTime = 1235 s
Cm = 7.08031
Cd = 13.1402
Cl = -0.259661
Cl(f) = 6.95048
Cl(r) = -7.21014
Time = 4
smoothSolver: Solving for Ux, Initial residual = 0.214588, Final residual = 0.0133585, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0770733, Final residual = 0.00473664, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.195012, Final residual = 0.0124302, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0177483, Final residual = 0.000176726, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00386416, Final residual = 3.5565e-05, No Iterations 10
GAMG: Solving for p, Initial residual = 0.000371768, Final residual = 3.54374e-06, No Iterations 23
GAMG: Solving for p, Initial residual = 5.95072e-05, Final residual = 5.70419e-07, No Iterations 25
time step continuity errors : sum local = 1.84151e-09, global = -1.82247e-10, cumulative = -1.25722e-10
smoothSolver: Solving for omega, Initial residual = 0.00788961, Final residual = 3.74303e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0656286, Final residual = 0.000343864, No Iterations 1
ExecutionTime = 914.35 s ClockTime = 1576 s
Cm = -16.2509
Cd = -29.4589
Cl = 0.694666
Cl(f) = -15.9036
Cl(r) = 16.5982
Time = 5
smoothSolver: Solving for Ux, Initial residual = 0.420152, Final residual = 0.025847, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.151328, Final residual = 0.00917183, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.724336, Final residual = 0.0454167, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0234195, Final residual = 0.000228815, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00359141, Final residual = 3.28205e-05, No Iterations 10
GAMG: Solving for p, Initial residual = 0.000347374, Final residual = 3.42699e-06, No Iterations 22
GAMG: Solving for p, Initial residual = 5.55193e-05, Final residual = 5.18951e-07, No Iterations 25
time step continuity errors : sum local = 3.52172e-09, global = 2.49334e-10, cumulative = 1.23612e-10
smoothSolver: Solving for omega, Initial residual = 0.00504652, Final residual = 3.29567e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0413384, Final residual = 0.000287633, No Iterations 1
ExecutionTime = 1117.53 s ClockTime = 1934 s
Cm = 35.4112
Cd = 62.5706
Cl = -1.46642
Cl(f) = 34.678
Cl(r) = -36.1444
Time = 6
smoothSolver: Solving for Ux, Initial residual = 0.540335, Final residual = 0.0328771, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.256176, Final residual = 0.0151566, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.749173, Final residual = 0.0459364, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0232613, Final residual = 0.000211777, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00378945, Final residual = 3.54794e-05, No Iterations 10
GAMG: Solving for p, Initial residual = 0.00036875, Final residual = 3.59724e-06, No Iterations 22
GAMG: Solving for p, Initial residual = 5.9962e-05, Final residual = 5.69627e-07, No Iterations 24
time step continuity errors : sum local = 6.98985e-09, global = -4.32232e-10, cumulative = -3.08621e-10
smoothSolver: Solving for omega, Initial residual = 0.00338321, Final residual = 3.0473e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0277725, Final residual = 0.000250897, No Iterations 1
ExecutionTime = 1308.15 s ClockTime = 2280 s
Cm = -73.1295
Cd = -126.245
Cl = 2.56818
Cl(f) = -71.8454
Cl(r) = 74.4136
Time = 7
smoothSolver: Solving for Ux, Initial residual = 0.752046, Final residual = 0.0448627, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.430047, Final residual = 0.0249392, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.551617, Final residual = 0.0336876, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0269677, Final residual = 0.000232386, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00380056, Final residual = 3.53977e-05, No Iterations 10
GAMG: Solving for p, Initial residual = 0.00037507, Final residual = 3.55969e-06, No Iterations 22
GAMG: Solving for p, Initial residual = 6.14032e-05, Final residual = 5.99133e-07, No Iterations 23
time step continuity errors : sum local = 1.41695e-08, global = 6.52369e-10, cumulative = 3.43748e-10
smoothSolver: Solving for omega, Initial residual = 0.00234028, Final residual = 3.02726e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0194432, Final residual = 0.000227259, No Iterations 1
ExecutionTime = 1491.96 s ClockTime = 2579 s
Cm = 146.466
Cd = 247.633
Cl = -3.05498
Cl(f) = 144.938
Cl(r) = -147.993
Time = 8
smoothSolver: Solving for Ux, Initial residual = 0.776731, Final residual = 0.0455646, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.558656, Final residual = 0.031481, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.653407, Final residual = 0.0383689, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0259683, Final residual = 0.000237545, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00340573, Final residual = 3.29827e-05, No Iterations 11
GAMG: Solving for p, Initial residual = 0.000344274, Final residual = 3.43903e-06, No Iterations 22
GAMG: Solving for p, Initial residual = 5.87626e-05, Final residual = 5.69208e-07, No Iterations 23
time step continuity errors : sum local = 2.49218e-08, global = 6.18566e-10, cumulative = 9.62314e-10
smoothSolver: Solving for omega, Initial residual = 0.00167082, Final residual = 3.52362e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0139952, Final residual = 0.00021044, No Iterations 1
ExecutionTime = 1673.7 s ClockTime = 2865 s
Cm = -287.239
Cd = -477.46
Cl = 2.13309
Cl(f) = -286.173
Cl(r) = 288.306
Time = 9
smoothSolver: Solving for Ux, Initial residual = 0.846681, Final residual = 0.0493988, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.717908, Final residual = 0.0404963, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.793609, Final residual = 0.0459932, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0262227, Final residual = 0.000249765, No Iterations 11
GAMG: Solving for p, Initial residual = 0.00303599, Final residual = 3.00778e-05, No Iterations 12
GAMG: Solving for p, Initial residual = 0.000305505, Final residual = 2.83807e-06, No Iterations 25
GAMG: Solving for p, Initial residual = 5.17231e-05, Final residual = 5.14271e-07, No Iterations 24
time step continuity errors : sum local = 4.23329e-08, global = -4.095e-09, cumulative = -3.13269e-09
smoothSolver: Solving for omega, Initial residual = 0.00125448, Final residual = 4.59583e-05, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0103348, Final residual = 0.000213194, No Iterations 1
ExecutionTime = 1859.81 s ClockTime = 3174 s
regIOobject::readIfModified() :
Re-reading object controlDict from file "/home/taeioum/OpenFOAM/taeioum-dev/run/pos/pos11/system/controlDict"
Cm = 547.583
Cd = 900.165
Cl = 2.90921
Cl(f) = 549.038
Cl(r) = -546.129
End
Finalising parallel run
I also did the checkMesh utility and it gave:
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
frontAndBack 4300 4524 ok (non-closed singly connected)
inlet 750 806 ok (non-closed singly connected)
outlet 750 806 ok (non-closed singly connected)
lowerWall 2580 2697 ok (non-closed singly connected)
upperWall 2580 2697 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-5535 -7.4607e-14 -8190) (6615 10100 26216)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (1.50014e-15 1.26354e-14 -9.2466e-17) OK.
Max cell openness = 2.17924e-15 OK.
Max aspect ratio = 108.81 OK.
Minimum face area = 0.00157481. Maximum face area = 173726. Face area magnitudes OK.
Min volume = 0.0160548. Max volume = 6.74569e+07. Total volume = 4.22204e+12. Cell volumes OK.
Mesh non-orthogonality Max: 64.9971 average: 8.1902
Non-orthogonality check OK.
Face pyramids OK.
***Max skewness = 5.20766, 1 highly skew faces detected which may impair the quality of the results
<<Writing 1 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
So is the problem relevant to the BC? Thanks a lot.
