April 29, 2019, 11:17 |
forceCoeffs plot error
Joe lee
Rep Power: 7 |
Hi Foamers, I used pimpleFoam to simulate an external flow, then I used the command:
foamMonitor ./postProcessing/forceCoeffs1/0/forceCoeffs.dat However, while my coefficient looks fine inside forceCoeffs.dat and log.pimpleFoam, the plot looks absolutely different from the data. Here is the plot: It seems all the value lies on the line only at time 0. May I know how to fix this? In case you need the whole case, I uploaded to google drive: https://drive.google.com/open?id=1EO...XIBP5iN33xp3rW Thank you very much!! |
April 29, 2019, 12:52 |
Rep Power: 12 |
This is an axis scaling issue on the gnuplot script part.
Disable the auto scaling and use a manual one ranging for such as 0 < y < 1 for plotting... |
April 29, 2019, 14:02 |
#3 | |
Joe lee
Rep Power: 7 |
I am just simply typing in Code:
foamMontion /.postProcessing/forceCoeffs1/0/forceCoeffs.dat |
April 30, 2019, 06:58 |
Rep Power: 12 |
I seems you are using a tool named foamMonitor and it uses gnuplot for drawing graphs automatically. I have no idea what foamMonitor is doing anyway so you have dig in the code.
Or you can directly import the *.dat file into any spreadsheet software and draw the graph manually. |
April 30, 2019, 12:42 |
#5 | |
Joe lee
Rep Power: 7 |
By the way, may I know if I have to use a script, how should I construct it? Is there any example coding? Thanks a lot! |
May 8, 2019, 09:39 |
Rep Power: 12 |
May 11, 2019, 11:59 |
#7 | |
Joe lee
Rep Power: 7 |
forcecoeffs, graph, pimplefoam, plotting |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
