Can't get residual plot for K and Omega ?!!!
Hello foamers,
I am making a simulation using the komega sst turbulence model and i am monitoring the residuals in real time but unfortunately i only get plots for the P Ux and Uy but cant get residual plots for the K and Omega ?! is there any suggestiong about how to resolve this issue?!! |
Is the turbulence turned on? How are you monotoring your residuals? We need more information to help you. Read the following post if you wan't better help with our problems in the future: https://www.cfd-online.com/Forums/op...-get-help.html Your problem can probably be solved by reading this thread: https://www.cfd-online.com/Forums/op...residuals.html |
Thank you for the Reply , in order to plot the residuals i have inserted this line in the controlDict File the flowing line functions { #includeFunc residuals } Code:
application pimpleFoam; and In order to monitor the Residuals during the simulation runtime i use the command Code:
foamMonitor -l -r 1 postProcessing/residuals/0/residuals.dat & but as i said before the only curves i get are only for p Ux Uy and i dont get plots for k and Omega also the strange thing is once i directly open the file /postProcessing/residuals/0/residuals.dat i only can see residuals for P Ux and Uy and there is no sgine for the k and Omega residuals. Hope you can help me |
I have never used that way to plot the residuals. I use either the way stated in the link I posted or using pyFoam: Code:
pyFoamPlotRunner.py theSolverIamUsing |
read the manual: "The default fields whose residuals are captured are p and U. Should the user wish to configure other fields, they should make copy the residuals file in their system and edit the fields entry accordingly..
https://cfd.direct/openfoam/user-gui...hs-monitoring/ |
Hi, could you please solve this problem? I am in the same case.
I would appreciate any help. Thanks in advance. |
Hello foamers,
I am making a simulation using the komega sst turbulence model and i am monitoring the residuals in real time but unfortunately i only get plots for the P Ux and Uy but cant get residual plots for the K and Omega ?! is there any suggestiong about how to resolve this issue?!! Thanks in advance. |
