The standard k-epsilon turbulence model cannot be used with Low-Re formulation. However you can use a Low-Re implementation, LaunderSharmaKE (it uses damping functions)
Hi Linda,
I dont know still you are looking for help regarding your Y+ and BCs. It seems that you are clear about the wall function approach and resolving the boundary layers. In your case, you are suppose to use Low Re k-Epsilon models. for low Re k-Epsilon I have posted BCs long back (2013). I hope still you can use it (Please check it), The boundary conditions are as follows (I used it for OF-2.1.1 Version), Low Re model: turbulence model : LaunderSharmaKE nut ----> fixedValue (0) k -----> fixedValue (1e-12) epsilon -----> fixedValue (1e-8) it can be zeroGradient as well nuTilda -----> fixedValue (0) for high Re model: nut ----> nutkWallFunction value (0) k -------> kqRWallFunction value uniform (*******) epsilon ----> epsilonWallFunction value uniform (*******) nuTilda -----> zeroGradient I hope it will be useful. If there is any issue, please post it here, Thanks, Sivakumar |
