How to evaluate Strouhal Number for a adjustable time step?
Like Tree4Likes
  • 1 Post By araujo
  • 3 Post By alexeym
Old   December 12, 2014, 00:10
Default How to evaluate Strouhal Number for a adjustable time step?
Leonardo Antonio de Araujo
araujo is on a distinguished road
Send a message via Skype™ to araujo
Hello all,
I'm working in the case of the flow around cylinder subjected to vortex-induced vibration in the transverse direction to the flow (y axis). How can I evaluate the Strouhal number (vortex shedding frequency) using FFT on the lift coefficient time series if the time-step of the simulation is adjustable? Thanks in advance.
amuzeshi likes this.
araujo is offline   Reply With Quote
Old   December 12, 2014, 01:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can either use interpolation, i.e. take points with variable interval, build interpolation function and then calculate values at constant interval. Then use FFT.
Or you can use The Lomb–Scargle periodogram (http://en.wikipedia.org/wiki/Least-s...le_periodogram).
In case of FFT you'll get frequency, in case of Lomb-Scargle you'll get 2*pi*frequency.
araujo, amuzeshi and s1291 like this.
alexeym is offline   Reply With Quote
Old   December 14, 2014, 02:01
Originally Posted by alexeym View Post
Thanks for your reply, it was very enlightening.
Old   August 24, 2019, 12:30
Ali Shayegh
amuzeshi is on a distinguished road
Dear Alexym,
Assuming we build interpolation function and then calculate values at constant interval, then use fft on ,for example, lift coeff in the case of vortex shedding behind a cylinder to obtain fft vector. Now we have to plot fft vector vs frequency vector in order to ,for example, find maximum amplitude. But, what is frequency vector? How to calculate it?
amuzeshi is offline   Reply With Quote
adjustable time-step, strouhal number, vortex shedding frequency
negative min.(alpha1) value interFoam Arjun Jayakumar OpenFOAM 11 December 21, 2019 10:59
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
